- Joined Jan 23, 2018
- 27,584
Use the hand cranked generator to charge the 12 volt battery. Use the 12 volt battery to power a cheap (square wave) inverter so that you have a 140 volt square wave. Use a full wave voltage doubler to give you 280 volts DC. Use ten amp 500 volt diodes and 450 volt capacitors in the doubler circuit. Beware, there will be a shock hazard.I was thinking along the lines of a 12VDC batery charged by a hand cranked generator, running some kind of invertor from the battery stepping the voltage up to 300VDC, do you think 300VAC would work better? I'm wondering if I used a transformer to step A/C voltage up from a 120VAC output inverter to 360VAC or 480VAC and then use a diode to rectify it to VDC would work, that would only give me roughly 1/2 of the VAC, that would put me around 180VDC-240VDC, am I right?
