Currently I have a 100 gallon pond (will be upgrading perhaps this year). The filter kit comes with filter elements, bacteria media and a UV-Clarifier lamp. Oh, and yes, of course, a pump. It's not possible to tell if the UV lamp is working without pulling the filter out of the water. I don't know if there's some sort of pressure switch that prevents the UV light from being active when not submerged. And for some reason those fluorescent type UV-Clarifier lamps seem to not last very long. Also, finding a replacement lamp - so far I've been unsuccessful. So I'm wondering if it's possible - or ill advised - to replace that fluorescent lamp with a UV lamp. Anyone have any suggestions? Recommendations? Cautions?
The current unit appears to run on some sort of ballast.
I don't know that it's critical to replace the ballast (if that's what it is) but I have no other way of verifying it's working. The unit that houses the lamp is at the bottom of the pond and difficult to reach on short notice. This (tracking disabled) appears to be a replacement lamp but I don't know how to get to the old one. And if I can figure out how to access it - I'd like to replace it with an equivalent LED type UV-C lamp.
The pump:
Somewhere in the garage - gotta go find it - is an older unit I can experiment with without putting the fish at risk. I'll update as I learn things about this pump.
The pump:
