From LTspice, I should be around 2v for VB-E:Your output transistors have ample margin on voltage and current. On power dissipation you monitored the temperature and did not see thermal run away. Typically BJT transistor fail short collector emitter (or excessive leakage between them). However if short B-E junction is seen (without C-E short) it may point to exceeding reverse B-E voltage. Your output stage is dual stage emitter follower (unity gain). The only way to exceed reverse B-E voltage is if the emitters are held by capacitors while the base is declining fast. This does not happen during listening music, where no high level high frequency is applied. This circuit has no current limiting and shorted load may be a risk. Can you examine your speaker cable/connectors for potential for shorts.
