Filters
Marc Sugrue
Joined Jan 19, 2018
222
Cutoff frequency is -3db. The fact the filter is second order just dictates the rate of roll off for the filter. The values of R & C you use will just move the -3db frequency in a passive circuit. In an active cofiguation you could also effect the gain of the circuit but this will be dependant on your circuit.
hero22222222222
Joined Dec 22, 2019
78
I found this on the internet that says it is for a LPF second order but I don't understand the graph
Marc Sugrue
Joined Jan 19, 2018
222
It has one that is -3db and the other that has -6db
The image is a bit deceiving as the 6dB doesn't really have a context
You need to understand the difference between "Roll off Frequency" and "Cut off Frequency"
Simplistically - Roll off is the steepness of the filter response. (shown as -20db/Decade and -40db/Decade) in your image
Cut off frequency - The -3db point is typically the point at which a filter starts becoming effective valid for both curves in the image.
I think what that image is trying to show is that with a higher order filter you can achieve a faster roll off
jpanhalt
Joined Jan 18, 2008
11,087
So?
Marc Sugrue
Joined Jan 19, 2018
222
