Hello Everyone,
I am interfacing HDMI Connectors with an Arm Cortex A series microprocessor for use in Industrial HMI Controller environment.
I would be using HDMI 2.0 or 2.1 data transfer rates.
I plan to use a HDMI companion chip such as the HDMI2C4-5F2 as a signal booster, ESD protection and level shifting of SCL, SDA, HPD, CEC & Enable pins. It also has a ESD diode for the VCC pin.
I would like to use some filters between the ESD diode and the microprocessor for better immunity from noisy industrial environment.
Circuit would typically be as :
Connector ----> ESD Diodes ----> Filters ----> Microprocessor HDMI pins.
(ESD Diodes and Filters shall be typically placed close to the connectors).
For the TDMS pairs, I would use 2 nos. of ECM4-2450A17M10 which has a ESD and common mode filter integrated in it.
However, I wish to know, what kind of filters are required for SCL, SDA, HPD, Enable and VCC pins.
Can you please recommend us some part numbers for the same.
Regards,
Gaurav
Regards,
Gaurav
