Filter LM4562 Output Saturation
Ian0
Joined Aug 7, 2020
13,132
Hey
The reason is to mimic a guitar speaker, you can see earlier posts comaring the response of a creamback driver and my filter
Oddly once implemented the fre isn't the same with v poor bass, will have to do some fiddling!
Two things to bear in mind:
1. The response plot on the datasheet is the response in an anechoic chamber. In a cabinet, and because the Qts value is high, there will be a peak in the 70-100Hz region. Thiele-Small parameters are rarely specified on lead-guitar speakers.
2. A guitar pickup has a rising response in the lowest half-octave. Output from the pickup is proportion to the size of the moving magnetic material and its velocity.
pdhaslam
Joined Dec 21, 2022
18
Ooo, thanks Ian, so i might not want an exact copy of the cream back frq response, but rather a bit more low end?
Would be smart of me to get a good ref mic and doa sweep on my actual cabinet I guess
Ian0
Joined Aug 7, 2020
13,132
Make the low end a 2nd order high-pass Chebyshev with a peak of about 3dB. A speaker in a closed box produces a 2nd order roll off. (4th order for a bass reflex cabinet)
Audioguru again
Joined Oct 21, 2019
6,826
Old speaker systems that produced "one-note-bass" usually resonated with a peak between 70Hz to 100Hz.
The old vacuum tube amplifiers for electric guitars did not have the extremely low output impedance of a modern solid state amplifier that damps speaker resonances.
Ian0
Joined Aug 7, 2020
13,132
No shortage of new speaker systems that produce "one-note bass"! Just listen as they drive past!
pdhaslam
Joined Dec 21, 2022
18
Hey Ian,
So, did as suggested and in LT spice looked great:
Into KiCad (just the high end bit shown):
Screenshot 2023-07-25 at 11.20.25.pngScreenshot 2023-07-25 at 11.21.49.png]
So for some reason that side of the opamp is oscillating rail to rail at around 3.7kHz which is about that high-end peak on the freq response. An un-damped resonance I'm guessing?
Wondering if my component placement is to blame? traces too long?
P
Ian0
Joined Aug 7, 2020
13,132
What is driving R24? It need to be a low impedance, such as an op-amp output.
It could also be coupling through the power supply, check your divider that forms the half-supply reference.
pdhaslam
Joined Dec 21, 2022
18
so R24 comes straight from Pin 1 of the other half of the opamp. The power supply is a +/-17V,
the whole section of the circuit is:
pdhaslam
Joined Dec 21, 2022
18
well solved it by adding 22k resistor to ground from the junction of r26, r24 and c19
i was think to try and bleed a little signal to ground before going into the non inverting input.....not sure that makes sense technically
