Filter help - calculating fc for this circuit
duff650
Joined Mar 15, 2019
38
I would appreciate some help understanding this circuit.
Am I correct in saying that R1 and C2 constitute a low pass filter and C1 and R3 are a high pass filter? struggling to comprehend whats going on, oi know its a band pass I have simulated the circuit with a 0.5V AC 1-10kHz testbench, here are the results
I got these values using 1/2*pi*RC for what I thought were the low and high pass filter, I need a low pass fc of 15Hz and a high pass of 75Hz with 11 gain, I know the gain is correct but can someone show me how to calculate the filter specs?
The cursors show the -3dB points and they are nowhere near what I expected, any help appreciated!
EDIT: I know the high pass before is there, ive calculated this previously
38,921
You are putting an AC signal that goes plus and minus into a single-supply op amp that can only go positive.
Add a negative supply or bias the input at 1/2 the supply voltage of the op amp for proper operation.
MrAl
Joined Jun 17, 2014
13,862
There is no C2 in the circuit.
As others have said, you need a negative supply too.
Given you have that negative supply too, you can analyze this circuit by substituting 4 impedances for the different circuit parts. You can then compute the output, then substitute actual values back in, and you get your response. That's about the simplest way to do this. Try again and then i'll show you how to do this, in part.
SLK001
Joined Nov 29, 2011
1,549
The fc (cutoff frequency) of a filter is defined as a point -3dB from the center frequency (power) or -6dB voltage. Use that relationship and calculate two fc's, or f1 and f2.
LvW
Joined Jun 13, 2013
2,038
You wrote "....-6dB voltage....".
I think, this is not correct. The classical cut-off is at a frequency where the voltage (magnitude) is 3 dB down .
