I'm working on a wireless power transfer project (operating frequency 100 kHz). As you probably know, ferrite is usually placed under the coil to create a low reluctance way and reduce the leakage flux.
How the coecive force Hc and the residual magnetic flux Br affect the hysteresis losse?
For example, in the attached file you can find different ferrite types with different Hc and Br.
What is the logical reasoning with which I should choose a soft ferrite with high Hc and low Br or viceversa?
Thank You.
Thank You.
