Hey all,
I'm currently fixing an amp for repair practice and am stuck on finding what I believe is a short circuit somewhere. I could care less about the actual amp and am doing this for the learning experience. It's a Fender Mini '57 Twin. Attached is a photo of the schematic that someone drew out and uploaded, as there weren't originals we could find.
The problem; I see 9VDC at the power input jack but once the switch is turned on, the power goes down to .5 VDC and a faint ticking noise is heard on the speakers.
I have;
-Replaced BOTH of the IC's and tested them and can see no shorts to ground on the pins of either IC. The ground terminals test continuity to ground
-Tested all capacitors which all read in the ballpark and none showed continuity
-Tested all of the resistors and saw good numbers and no continuity
-Removed the power switch, as process of elimination, and hardwired it. Same result
-removed the female power jack and hardwired that, just to see. Same result
-replaced the D3 Diode.
-Made sure all ground points read correct continuity
-Tested the other two diodes and read good
-Also looked for bridging and found none between points on PCB
-Tested all pots and their ground connections
Any suggestions?
I have;
Any suggestions?
