Faulty wine cooler - please help
Status
Not open for further replies.
Ofirshw
Joined Dec 23, 2023
15
I have a TEC wine cooler with a board that is very similar to this:
I found a schematics that looks consistent with what I see: (capacitor values, etc.):
The cooler has a hard time to start. Meaning, I see that the LEDs are blinking very lightly and sometimes it successfully starts. Sometimes they just keep blinking and it keeps the "trying to start" state.
When I disconnect the interior fan (CN2) then it starts almost immediately (LEDs blinks for a fraction of a second) but when I connects it back it's having a hard time. Also, when I disconnect the TEC it starts without any issues.
I checked C10 (the usual suspect) and it's ok. I also checked one of the big caps that looked perhaps suspicious (one of the 120uF caps) but it's ok.
Looking at the circuit I suspect C8 or one of the diodes, but I want my next dive in to be analytic, so I ask your help with the evidence I brought.
Thanks!
wayneh
Joined Sep 9, 2010
18,169
C8 is the usual suspect. Replace it. The symptoms you describe are typical. Did you see the threads here on the issue?
Since the fan load seems to exacerbate the problem, you might want to verify the fan isn't bad. That actually happened with mine. But I'd replace C8 first and see how it goes. Make sure you find a replacement with low ESR, high temperature rating and long lifetime. Pay attention to dimensions - it can probably be taller than the original but it can get hard to replace if the diameter or lead diameter is larger than original.
Ofirshw
Joined Dec 23, 2023
15
Is C8 the usual suspect of this schematics? I thought that in this one it's the C10, which feeds all the high current devices, and if I recall correctly it is called C8 on other schematics.
Can you please have a look at the schematics I provided?
The fan on CN2 works well, so I suspect it's not it.
Thanks!
35,199
Since the photo of the PCB shown is not yours, post a photo of your board (both sides) so that we can compare the two boards.
Ofirshw
Joined Dec 23, 2023
15
Thanks!
So I deep dived in my previous situation and it was indeed the same C8 shown here.
I replaced it by a new one and now it works perfectly. Thanks!
I'll post that in the success story thread.
SAali
Joined Oct 9, 2025
Good morning. Thank You for sharing the PCB layout. I lost the existing capacitor. But through this drawing I get the Part values.
Thank you.
Status
