Need help to get the firmware from faulty IC
murshaid
Joined Mar 24, 2025
13
Need help to get firmware from MX25L8006E. Problem is that the VCC and Gnd are shorted by connecting multimeter even if the IC is out of its PCB
schmitt trigger
Joined Jul 12, 2010
2,224
If the device shows a short between ground and Vcc, then the device is internally damaged, the internal information gone forever.
I understand that this answer is not what you want to hear.
If it's your million dollar Bitcoin password on the chip, then, there some people (I know) with access to semiconductor yield probe analysts gear that might be able to do a one time chip strip and die level probe for a ridiculous sum of money unless you work for a three letter agency. Then the price goes to a ludicrous sum of money.
Papabravo
Joined Feb 24, 2006
22,111
You still may be out of luck since most devices with firmware have a security fuse which would prevent you from doing what you want. @nsaspook alluded to people who can open the package and use a scanning electron microscope to read the contents of the program memory. This process does not come cheap.
Ya’akov
Joined Jan 27, 2019
10,295
If you happen to be able to decap the chip and have a SEM handy, then with a few days labor and some specialized software tools you might be able to manage it...
In other words—you are, unfortunately, out of luck.
