MaxHeadRoom
- Joined Jul 18, 2013
- 30,807
I recall when we did the dynamic braking mod, my brother 'wrestling' with the cables going up to the roof resistance banks. !
How heavy would you guesstimate that contactor to be? Just thinking about how much weight it might add and whether it'd be overkill or not for my use case. I'm hoping to keep this thing hand-portable by one person, with a second needed only for the dragging of it up the steps into the cab. Thinking of putting some shallow Unistrut 'skis' along the bottom of it to help it slide easily along steel surfaces for that reason.I recall when we did the dynamic braking mod, my brother 'wrestling' with the cables going up to the roof resistance banks. !![]()
My heart, my little heart. Love it.
Like in a accidental cable Black/Red end swap?Any pointers as to where to start designing a polarity detector circuit with an output which can be used to interlock the signal controlling the power contactor?
Interlocking is important here because the knife switches on older locomotives are not marked for polarity. Very easy to get it backwards if you're not paying attention.Like in a accidental cable Black/Red end swap?
The most likely polarity error is IMO the jumper ends being swapped on the device being jumped or less likely, at the energy source connection. If there is residual voltage (not completely dead) on the remote device connection terminals, that can be used to interlock the charging contactor with something as simple as a diode and low voltage DC relay with a voltage limiting device like a zener and series resistor. The energy source side can have a similar interlock or it can be just an indicator LED being GREEN for the correct polarity connection.
Right now we just test the polarity with a voltmeter before applying jumper leads. That works, but does not eliminate the opportunity for human error.I understand that. What are the current standard methods of making sure that doesn't happen?
Using passive devices example: Just a starting point for possible solutions.Right now we just test the polarity with a voltmeter before applying jumper leads. That works, but does not eliminate the opportunity for human error.
The challenge I am facing here is that I am trying to test the polarity of an unknown, variable voltage between 0 and 74 volts DC. It's difficult for me to come up with a solution which would work for that.
I have seen some diagrams depicting the use of a FET, a zener diode and a pull-up/down resistor that should work on variable voltage, but the challenge then becomes turning that variable voltage "go/no-go" signal into a useful output, either in the form of a regulated logic-level output or a dry contact. (A relay coil is wound for a definite voltage, and so probably won't play nice here.)
Another consideration is the voltage drop during cranking. The logic output of this circuit needs to be maintained even if the battery voltage tanks to some absurdly low level, like 6 volts.
The start contactor weighs in at around 15Kg (33lbs) !
If the boards came in Velostat (metalized bags) they should be OK, provided you opened them in a static safe environment. If they came in Pink Polly bags - while PP doesn't generate static it doesn't protect against it either.the seller decided to ship them immersed in styrofoam packing peanuts so I need to bench test each and every one of the balance boards to make sure they haven't been killed by ESD
Nope. Directly immersed in peanuts.If the boards came in Velostat (metalized bags) they should be OK, provided you opened them in a static safe environment. If they came in Pink Polly bags - while PP doesn't generate static it doesn't protect against it either.
Oh, and building on a rug is never a good ESD practice.
Oh geez! Hope you took pictures.Nope. Directly immersed in peanuts.
