I can find lots of powerstrips ( https://www.amazon.com/gp/product/B00ACZPZIU ) that are autoswitching to save electricity by urning off outlets when a device on a control outlet is not drawing current. What I want to do is the opposite - to power on a separate outlet when the device on the control outlet is NOT drawing current (ie normally-closed relay).
If there are no smart power outlets / powerstrips on the market that do this (for a reasonable price), I am thinking about buying a relay and wiring it myself.
It would modify the functionality to turn it into a fail-over power device by inverting the relay functionality that is built in from functioning as “normally open” to “normally closed” using an ac to ac relay (https://www.amazon.com/gp/product/B08TR7WJX2). As a result, when the device on the control outlet (a fan) fails, the outlet would detect the drop in current and turn ON the other outlets, powering another standby fan.
Can anyone either suggest where I might find such a device, and if not, can you weigh in on this design?
Thanks.
Thanks.
