Auto failover to battery in case of a power fail, and auto return to mains supply on power restoration
Rob_Bradford
Joined Jul 3, 2023
Hi
I am a retired engineer, my question is as follows:
How do I auto switch over from mains supply, regulated down to 9v, to battery without dropping power, and return to mains power from battery after a power drop.
Cheers.
Rob
Rob_Bradford
Joined Jul 3, 2023
OK I am a bit "old school" so would like to avoid specialist power detection chips, but if that is what is needed OK, I have no objection to large capacitors being housed in my casing to cover the failover/ recovery. I am running a load of data loggers across my garden to monitor the environment to improve it to boot wildlife and insects, I am a bit remote from (CMP's [Centers of Mass Population]) so power drops are fairly short but not infrequent.
Rob
ericgibbs
Joined Jan 29, 2010
21,421
Hi Rob,
If your system can tolerate a small voltage drop, say 9V down to 8.3v, you could do the auto selection with two Schottky diodes
E
BobTPH
Joined Jun 5, 2013
11,491
Make sure the adaptor voltage is a little above 9V, then feed the power from each through a diode. When the power is on, the battery will be out of the circuit because it is reverse biased. When it goes off, the battery supplies power.
Rod777
Joined Aug 24, 2019
11
Also an old timer, I would put a 9.1V charger across the battery. If the power fails there is no delay as the battery is always across the project.
Bulldoggie63
Joined Jun 24, 2021
14
Hi
Cheers.
Rob
Also being old school, I follow the KISS method. Keep it simple stupid. And what could be simpler than a relay?
Mains go down, relay drops out switching to the battery backup.
Bulldoggie63
Joined Jun 24, 2021
14
Two diodes. No moving parts. Switches far faster.
We may be missing part of the issue.
Is he trying to run a power supply in parallel to a battery backup? Or does he want isolation also?
Plus relays are time proven and durable. Less prone to damage due to power spikes. I've replaced many fried diodes. And I have only had to replace one fried relay that wasn't burnt in a fire.
Also, I'm a former radio engineer that is aware of the harsh conditions that remote and infrequently tested gear has to go through.
Bulldoggie63
Joined Jun 24, 2021
14
I may not have explained my suggestion well enough for the youngsters to understand.
Use a relay with the coil powered by the mains. The basic low voltage power supply is connected to the NO contacts. The battery backup is attached to the NC contacts. With the equipment power feed on common.
Mains power keeps the coil energized. When the mains go down, the relay cuts loose and switches to the battery backup. When power is restored, the relay re-energizes.
KISS
Of course you can add on things like a capacitor bank and then an indicator light. Maybe even a remote indicator of the relay status. All just using a relay.
KISS with durability and options.
BobTPH
Joined Jun 5, 2013
11,491
Go back and read the first post. He is trying to run a 9V device from a mains to 9V supply with a battery that takes over when the mains supply is interrupted.
Yes, a relay will work but I think two diodes is simpler, smaller, faster, quieter, cheaper and more reliable. You may disagree, no problem. Nothing wrong with having options.
Bulldoggie63
Joined Jun 24, 2021
14
True. And, for every electrical problem, there are at least 27 solutions.
We are here discussing an issue without all the facts. Such as actual layout and power conditions.
