extremely strange circuit behavior - looking for an advice
schmitt trigger
Joined Jul 12, 2010
2,249
This thread is a perfect example of the XY PROBLEM:
The XY problem is a communication issue that occurs when someone asks for help with a solution (X) instead of the actual problem (Y). The XY problem can cause wasted time, miscommunication, and ineffective solutions.
And I would add, a very poorly described solution.
BobTPH
Joined Jun 5, 2013
11,659
No idea why you are saying that current breaker is way to no.
Because the current changes from 0 to 100% 100s of times per second. Sensing the current does not do what you want.
The monostable gets around this by extending the pulses so that they are continuous when the PWM is operating. This is what you need to drive a relay.
Likewise, converting the PWM to an analog voltage does not do what you want. It could almost work, but would fail for very low duty cycles. You cannot set the threshold to zero because there is always noise and inaccuracy in the system. And even if that was not the case, a comparator can only have a threshold of zero when it has a bipolar supply.
The solution I proposed will work in all cases with only the 12V supply you are already using. You will not find a a prebuilt module that does exactly what you want.
thor21
Joined Sep 29, 2024
435
but how can current chance or be higher than 0 in case stripe is off?
did you mean even the the strip is OFF: both current and voltage changes oscillating between 0 to 100%?
okay makes sense, but someone has to design it, correct?
thanks!
BobTPH
Joined Jun 5, 2013
11,659
Yes! That is what I have said twice now. That is what PWM means.
And the problem is not that that is current when it is off, bit that the is no current part of the tine when it is on.
A missing pulse detector works by changing state when it does not see a pulse within a specific time period. When the PWM stops it will change state after a little more than one period later. That means, probably a few milliseconds at most.
boostbuck
Joined Oct 5, 2017
1,064
It's like you have junior computer engineer and you force him to understand complex algorithm where knowledge of multiple prerequisites is required....
For me it's enough if someone says use that module connect it as that and thats it... Instead of addressing I have to understand ohm law... Pwm... Etc etc..
You've been told what circuit to use, and now you are debating it's correctness.
The 'missing pulse detector' is the conceptual solution to detecting the light 'on', turning the varying PWM signal into a binary on-off.
You are forcing yourself to try to understand it! It's a shame there doesn't seem to be a prebuilt module for that purpose, but keep looking.
BobTPH
Joined Jun 5, 2013
11,659
There is another conceptually simpler circuit that would probably work well. If you charge a capacitor though a diode, with resistor to discharge it over a period or two, it will perform pretty much the same function. But will need a transistor to drive the relay and will not switch sharply like my original idea. It will end up with about the same number of parts and is not quite as good. That is called a peak detector. It is complicated in this case because of the ground line being switched, making it “upside down” from a circuit you are likely to find.
You need to get over the fact that there is no trivial solution and not likely a module that does exactly what you need.
boostbuck
Joined Oct 5, 2017
1,064
Ok, after wasting too much time on the web, I have only found two modular solutions: the RC community has lots of PWM detector modules but designed for RC servo pwm, and it seems the perfect module functionally but for industrial applications.
I think you are going to have to roll your own. Personally I'd reach for a 555 as a missing-pulse detector, with an inverted output turning it into a pulse-present detector. Easy as, bro.
thor21
Joined Sep 29, 2024
435
understand, i think now i do understand that missing pulse detector and its usage for my case...
I am its fine ... but isn't that https://circuitdigest.com/electronic-circuits/missing-pulse-detector-circuit-diagram
providing the Solution for that? I mean if its schematically (circuit design ) is correct, its not problem to get it "created" and to install it?
boostbuck
Joined Oct 5, 2017
1,064
Who is 555?
Are you just playing games here? Way back in post #30 Bob suggested an LM555 as a missing pulse detector can be configured as a PWM detector. There are numerous examples of this on the web, such as the one YOU discuss in your post #54 - that is all about a missing pulse detector using a 555. Did you even read it?
The module I linked to is an PWM detector, an industrial version of what you need. The ONLY modular solution I could find, and no doubt extremely expensive and possibly not exactly appropriate to your requirements, but I haven't bothered to look into it.
thor21
Joined Sep 29, 2024
435
yes i got it afterwards... that you are referring to LM555. but i also believe in case i contact them they dont care :)
