extracting cgg and dgs from LTSPICE simulation model
Papabravo
Joined Feb 24, 2006
22,113
I think you meant gds. The quantity dgs does not appear to be a MOSFET property. A discussion of gds as the inverse of rout is contained in the following article.
https://en.wikipedia.org/wiki/MOSFET
As for cgg, it appears so be the parallel combination of cgs with the series combination of cgd and cds.
Also remember that cds gets shorted out when the MOSFET is on.
I hope that helps.
yef smith
Joined Aug 2, 2020
1,485
Hello Papabravo, gds is the derivative of the current by vds.
for Ft plot ineed the Cgg i have found another formula
my spice model is shown bellow.
so Cgg=Cgs0+Cgd0+Cgb0
in my model its
+CGDO = 8.23E-10 CGSO = 8.23E-10 CGBO = 1E-12
Alll the capacitances are in parralell, as shown bellow.
I am correct?
Thanks.
CGSO Gate-source overlap
capacitance/channel width
CGDO Gate-drain overlap
CGBO Gate-bulk overlap
https://sanjayvidhyadharan.in/Downloads/tsmc_180_nm/tsmc018.lib
https://www.seas.upenn.edu/~jan/spice/spice.MOSparamlist.html
Audioguru again
Joined Oct 21, 2019
6,826
I could not find a datasheet for that Mosfet. The Model has no minimum and maximum specs, probably just "typical" specs.
The DC simulation here does not care about capacitance.
