external ADC interfacing with MSP430F6736
keval.desai
Joined Jun 1, 2018
15
I want to interface an external ADC (ADS1231 24-bit) with MSP430F6736 to read analog data and display it on a screen (monitor).
I have a MSP-FET (Flash Emulation Tool) and a MSP-TS430PZ100B 100 pin target board.
I want to read analog data (voltage) and display it on the screen.
What steps do I need to follow?
Thank you.
danadak
Joined Mar 10, 2018
4,057
Just a thought, but there are parts out there, UPs, that have hi res onchip
A/D (20 bit) + Reference + ARM core + lots of other stuff like LCD interface -
Note A/D has differential input to handle bridge sensors.
Regards, Dana.
danadak
Joined Mar 10, 2018
4,057
What is the screen ? PC or LCD ?
In general your processor has to implement the two wire interface to A/D,
and then if PC is display device some code, like Python, to display the
data. If specifc LCD incorporate a library in code base to handle it.
Regards, Dana.
keval.desai
Joined Jun 1, 2018
15
Regards, Dana.
Hey Dana,
The screen is a PC.
Will I be able to generate a text file or an excel file to record the data using C?
35,120
The MSP430F6736 already has an 8-channel 10-bit 200ksps ADC and a 24-bit sigma-delta ADC.
Why do you need an external ADC?
danadak
Joined Mar 10, 2018
4,057
Look at all vendors very carefully at end to end signal path errors,
not all A/Ds and G elements are equal in their inaccuracy specs.
PSRR, T, Power, Noise, non linearity.......
Attached a basic ap note on error sources, Analog Devices has many
other sources of discussion on this topic.
Regards, Dana.
keval.desai
Joined Jun 1, 2018
15
Hi Dana,
I have moved on from interfacing external ADCs to using the internal ADCs for conversion process.
I have finished the coding for it but I am stuck on storing/exporting the data to an excel sheet.
Could you help me out with a way to export the data into an excel sheet?
Thanks,
Keval
