Exporting data from lt spice
Soma23
Joined Apr 24, 2015
60
How i can export the data from spice?
Such that when i draw a circuit consists of : 1 resister , ground , with AC supply .
I want my data to be like this
Ex:
R1 1k at a time .1s the power was 1 mw and so one
How i can get this ?
Soma23
Joined Apr 24, 2015
60
But i did not get the needed data
My data should be like this
At time 0 the power forexamplee .2W and so on
Can somone explain this
ericgibbs
Joined Jan 29, 2010
21,557
That LTS print out has 4 headings and 4 columns of data, what do you want explaining.?
It would be helpful if you posted your LTSpice asc file.
E
Soma23
Joined Apr 24, 2015
60
here itis
Here i put 3 resisters
I want to export the data like this
Time then power of each resister at each time
ericgibbs
Joined Jan 29, 2010
21,557
hi,
This is the Exported text file for your asc sim file, the .tran is 0.5msec and the max time step is 100usec, this reduces the number of value in the text file.
Is this what you are asking.?
EDIT:
This is the Export file opened by Lotus 123
Soma23
Joined Apr 24, 2015
60
Yes thank you
how i can show the output as waves ( like sin and cos) not like this?
Do you know how i can show the output as a waves ( like sine and cos ) not like ablocks??
ericgibbs
Joined Jan 29, 2010
21,557
You choose a .tran period that related to the frequency of the AC source.
eg: if AC1 is say 1KHz, then I would use .tran as 1mSec.
Also use Max Time step in the .tran set up to give the required number of samples in your exported file. OK.?
If you have another asc file, please post it and we can discuss it.
E
Soma23
Joined Apr 24, 2015
60
What is in the photo is exactly what i am looking for could you please show me the window that you put that values in ?
Soma23
Joined Apr 24, 2015
60
Thank you
What does 100 u means?
Actually i have to draw Ac circuit is the way that i did is correct?
I read that to compute the power in AC circuit we have to read irms and vrms with the power factor
While in DC circuit IV is enough , am i write ? Is my simulation is correct ?
ericgibbs
Joined Jan 29, 2010
21,557
hi,
To see the Average value in LTS, run the simulation, hold the Ctrl key down and left click on the Plotted label name.
The RMS value is 0.707 * the Peak value.
100u == 100 micro seconds
Is this a homework problem.?
Soma23
Joined Apr 24, 2015
60
No i have to use. A simulation software for my senior project so i want to make sure that this software can give me what i want to use it and simulate my project
ericgibbs
Joined Jan 29, 2010
21,557
LTSpice is good simulator for most circuits, its also free.;)
When you have designed your circuit post the asc file so that we can help you.
Soma23
Joined Apr 24, 2015
60
Thank you so much butdidn't understand
Does spice calculate this already so i do not need to worry about it ?
Soma23
Joined Apr 24, 2015
60
Still couldn't find it
I found it
But i didn't understand why should i do this thing ?
why it is integral not rms ?
