Euler's Number
peek65408
Joined Dec 20, 2013
2
Sorry if this is too nit picky...
Should replace "Euler's Constant with Euler's Number"
Volume III - Semiconductors » Diodes And Rectifiers » Introduction
http://www.allaboutcircuits.com/vol_3/chpt_3/1.html
The two diode formulas incorrectly refer to 'e' as Euler's Constant, when it is actually Euler's Number. Euler's Constant (gamma) is a different value (0.5772156649...), and Euler's Number 'e' (Napier's Constant) is 2.71828...
33,040
You are correct. I'm aware of the distinction, but frankly can't keep it straight in my mind which is which and since I have never actually worked with the Euler Constant (that I can recall), I tend to not notice when the Euler Number is misidentified as the Euler Constant.
Hence, I do think it would be good not only to correct the terminology in the E-book, but to burn up a sentence or to pointing out that there is a different constant that is also named in his honor and that constant is called the Euler Constant. No need to go into any further detail. The way the OP described it is probably sufficient.
Dcrunkilton
Joined Jul 31, 2004
422
I have changed image 13048.png to reflect Euler's Number instead of Euler's constant at ibiblio.
Credited to peek65408 in the Contributors List at ibiblio.org
Thanks for being smarter than I,
Dennis
