We are using Ethernet switch IC for communication in MII interface of the device we have pins for RXDV, TXER, TXEN, RXER with following definition.
My question is will they be considered as digital signals or all the attributes of MII data lines also be applicable to them? Specifically routing attributes.
Extending this question also to CAN, will CAN TX,RX s/g also be considered as analog or digital and will routing be same as data line i.e CAN H,L?
Thanks in advance.
Thanks in advance.
