Thanks again,
I had the potentiometers in mind specially to control the gain and to achieve circuit stability.
I have studied the circuit you sent and I have some unclear points:
The OPA at the bottom Right is used to increase the Vsh level what I did not get is why it is provided through the resistors to the control OPA in the middle?
- why do we have the control signal connected to the resistor to the vp? (Is it a normal pull up resistor and would not this open the mosfet if the control signal is 0?)
-why do we have a voltage divider before and after the buffer OPA (control signal input and output)
I am so sorry for asking too many questions.
