Pic to esp32
geoffers
Joined Oct 25, 2010
520
Hi all,
Not been on here for a while! I've a question/would like some opinions on learning to use esp32.
I've been programming (not professionally) 8bit pic for quite a while now (25years on and off I reckon) and recently been fairly successful (hence lack of visits here)
I code in mpasm relocatable and last few years non blocking code, gave me headaches to start with!
I've a project coming up where I want to read a flowmeter via rs485 (modbus I think but haven't got the meter yet, AliExpress special)
I also want to read the forward speed of a tractor via can bus.
This is to give a drive faster/slower indication for spreading slurry with a pumped umbilical system.
Rs 485 and modbus I have already used on a pic, can bus I haven't.
The esp32 has can and rs485 on it and the options for some nice displays.
How much of a learning curve is involved for a dinosaur like me to go from my current experience to programming esp32 in c (I assume via Arduino ide would be best?)
Can anyone recommend any good books on c for such applications.
As I write this I'm more inclined towards digging out a pic16 and using a simple LCD display and keypad.
Advice appreciated.
Cheers Geoff
panic mode
Joined Oct 10, 2011
5,281
do you really need CAN bus? just saying there are other ways to get speed.
for example using GPS one can get speed, location and much more... plus it is completely vehicle agnostic so can be tested by walking, riding bike, driving car...
Code:
#include <TinyGPS++.h>
#include <HardwareSerial.h>
TinyGPSPlus gps;
HardwareSerial ss(2); // Use UART2
void setup() {
  Serial.begin(115200);
  ss.begin(9600, SERIAL_8N1, 16, 17); // TX, RX
void loop() {
  while (ss.available() > 0) {
    if (gps.encode(ss.read())) {
      if (gps.speed.isValid()) {
        Serial.print("Speed: ");
        Serial.print(gps.speed.kmph());
        Serial.println(" km/h");
CAN bus example:
Code:
#include "driver/twai.h"
// Define CAN Pins
#define CAN_RX GPIO_NUM_4
#define CAN_TX GPIO_NUM_5
void setup() {
  // Initialize configuration structures
  twai_general_config_t g_config = TWAI_GENERAL_CONFIG_DEFAULT(CAN_RX, CAN_TX, TWAI_MODE_LISTEN_ONLY);
  twai_timing_config_t t_config = TWAI_TIMING_CONFIG_250KBITS(); // Tractor standard
  twai_filter_config_t f_config = TWAI_FILTER_CONFIG_ACCEPT_ALL();
  // Install and start CAN driver
  if (twai_driver_install(&g_config, &t_config, &f_config) == ESP_OK) {
    Serial.println("Driver installed");
  } else {
    Serial.println("Failed to install");
    return;
  if (twai_start() == ESP_OK) {
    Serial.println("Driver started");
  } else {
    Serial.println("Failed to start");
void loop() {
  twai_message_t message;
  if (twai_receive(&message, pdMS_TO_TICKS(1000)) == ESP_OK) {
    // Check if the message is PGN 65265 (Hex: FF11)
    if (message.identifier == 0x18FEEE00) { // Example for Cruise Control/Vehicle Speed
      // Data byte 1 & 2 contain speed (varies by specific tractor model)
      float speed = ((message.data[1] << 8) | message.data[0]) * 0.00390625; // Example scaling
      Serial.print("Speed (km/h): ");
      Serial.println(speed);
panic mode
Joined Oct 10, 2011
5,281
for learning, just talk to google AI for example:
"how to display tractor forward speed using esp32 and arm of a servo"
"how to read tractor speed using esp32 and can bus"
"what esp32, display etc i need to do ...xyz?"
get the parts connect them and if you don't have it working in a day or so something is very wrong.
geoffers
Joined Oct 25, 2010
520
I think you maybe right about learning c on pic first. Every time I think about doing i decide it will be quicker in asm as I know what I'm doing.
How easy is it do non blocking code in c? I have got a bit out of touch with stuff since had kids!!
There is already a socket in the cab of the tractor with a speed output I believe over CAN bus, I get what your saying about other ways to get speed but I think it would be cleaner to use that if I can. Has a 12volt supply too.
I'll confess years ago I bought a book on coding in c++ to write computer code but got a bit bogged down trying it. Maybe it was a bad book but I've found python and Java easier for small programmes on pc.
Irving
Joined Jan 30, 2016
5,195
Very easy, depending as always on the detail. ESP32 comes loaded with FreeRTOS so creating task-based parallel processes, etc is pretty straightforward. The application you're mooting is easily within an ESP32 dual-core's capability.
geoffers
Joined Oct 25, 2010
520
I think I posted too soon!
This is the pin out for the connection in the cab, I don't know why I assumed it was attached to the canbus, maybe because the others are!
This should be easier to interface to with a pic than going via can.
I have radar corrected speed on the tractor so should be quite accurate.
If you want to learn bare-metal C programming on a controller, start with something simple like a 8-bit controller. Jumping into ESP32 API level C programming is pretty much asking to race a car with just a learner's permit. ESP's are not intended to be used "bare-metal", the detailed low-level documentation is poor or missing so most use the ESP-IDF to build on the RTOS framework. If you need Wi-Fi and Bluetooth they are great, if you don't, there are tons of better controllers to learn on.
https://docs.espressif.com/projects/esp-idf/en/stable/esp32s3/api-guides/hardware-abstraction.html
https://www.paaet.edu.kw/media/bk2o0hww/analysis-of-free-rtos-vs-bare-metal-using-esp32.pdf
John P
Joined Oct 14, 2008
2,068
If you're a beginner, start with an Arduino. It's been very cleverly designed to be easy for a person with limited skills to connect to a computer and get something running quickly. And users have been very helpful, by creating libraries to do all kinds of tasks (CAN bus and RS485 definitely included) which you can get for free and easily install. No special equipment needed, just connect it to your computer with a USB cable, and that provides power, gives you a programming interface and when the program runs, allows you to communicate with it.
panic mode
Joined Oct 10, 2011
5,281
create state machine and use as many states as needed...
example using enum:
Code:
typedef enum { STATE_IDLE, STATE_RUNNING, STATE_ERROR } State_t;
State_t currentState = STATE_IDLE;
void update() {
    switch (currentState) {
        case STATE_IDLE:
            if (input_received) currentState = STATE_RUNNING;
            break;
        case STATE_RUNNING:
            // logic...
            if (error_occurred) currentState = STATE_ERROR;
            break;
geoffers
Joined Oct 25, 2010
520
Well the flow meter has arrived and works .
It's from Ali express so documentation is sparse, looks like it communicates over rs485 modbus rtu protocol?
My rs485>usb is gone wrong so will have wait a bit try and talk to it.
Definitely using a pic as I've already written code for modbus rtu on another project.
Any suggestions for a good book on embedded c? I use mplab x, I think it's the xc8 compiler I would need to use.
I assume I can write some parts in asm and some in c if I go that way.
It would seem make sense use c for the arithmetic section, that normally gets fairly involved in asm.
What is like to end up with is a display in cab to show me flow rate and target speed for a given application rate. Then LEDs to tell me to go faster or slower. The flow rate varied by 40% in one field on Friday from top to bottom which surprised me a bit.
Cheers Geoff
Cheers Geoff
Great. There's no real need to mix asm with C for this sort of program. A simple FSM (communication and data extraction/formatting from the returned sensor data) for the modbus connection and a main calculation and display routine for the display is simple in C. If you need help with XC8, just ask.
My bmc_slave code has several examples of MODBUS sensor routines for the Q84 pic controller.
Clone (with git) to a local directory.
https://github.com/nsaspook/mqtt_comedi/tree/opifixes
https://github.com/nsaspook/mqtt_comedi/tree/opifixes/Q84
Doxygen files: https://github.com/nsaspook/mqtt_comedi/tree/opifixes/Q84/html
Screenshot 2026-05-18 at 11-02-19 My Project bmc_slave.X_pzem_rtu.c File Reference.png
Screenshot 2026-05-18 at 11-00-10 My Project bmc_slave.X_pzem_rtu.c Source File.png
geoffers
Joined Oct 25, 2010
520
Thanks, I'll see where this goes, have just downloaded the latest mplabx and xc8 to my new pc.
Used real term and rs485 adapter to confirm it talks in modbus rtu, I'm just waiting on the vendor to send me a data sheet for the modbus registers. I can pick out the file for total measured easy enough. If I don't hear anything I'll have to pump some slurry through and find the flow rate file that way.
It's a glamorous old job
Sensacell
Joined Jun 19, 2012
3,789
As a 64 year old geezer that has been coding and building hardware my whole life:
I am currently working on my first big AI coding project, what I can tell you is this:
Now I can spend my mental bandwidth on something productive and useful, rather than grinding through code. I use my smarts now on the BIG PICTURE- gone are the days where I would accept sketchy compromises - simply because I burned out.
The darkest era was the 2010's - this is where the expectations of code went through the roof, while the tools to accomplish the work barely kept pace. At this time I truly felt despair, It just seemed that the job got harder every day, and I saw no solution on the horizon. With AI, it's actually fun to do this stuff again, all my experience comes into play when I write the specifications, and when I debug things, I don't feel that AI threatens me- it gives me wings.
Install Claude Code and give it a whirl.
Don't use AI to learn anything. Use if after you're an expert. Coding was always the easy part (I still love building things from the bolts up, because that's where you have the time to think about practical programming design), the BIG PICTURE is computer programming, not coding.
geoffers
Joined Oct 25, 2010
520
I've been plodding away at this now, have got a bit lost in the c data types.
I was quite supprised how quick it was to get the basics sort of going, Ive got a 16f1827 talking to a lcd display. Interrupts working etc.
I'm try to sort out the modbus side of things now, I've done this in asm before but need a bit of help!!
I've a message to send
0x01 0x03 0x00 0x01 0x00 0x02 + crcl,crch I've created uint8 files for each bit of the message and can send them to my display using printf.
I'm coming unstuck trying to join them together for the crc calculation.
In asm I used the fsr registers and was quite straight forward.
I need to calculate the crc of the message value, but that is over the whole message.
0x010300010002.
At the moment I could just send that message and try and interprate the reply but I can see I might want to alter one part of the message in the future?
Or should I create a seperate deffenition for each message rather than split it up?
Cheers Geoff
For simple fixed MODBUS sequences this is what I do for the current project using a Q84
C:
static const uint8_t
// transmit frames for commands
modbus_em_id[] = {MADDR, READ_HOLDING_REGISTERS, 0x00, 0x0b, 0x00, 0x01}, // Carlo Gavazzi Controls identification code
modbus_em_version[] = {MADDR, READ_HOLDING_REGISTERS, 0x03, 0x02, 0x00, 0x01}, // Firmware version and revision code
modbus_em_data1[] = {MADDR, READ_HOLDING_REGISTERS, 0x00, 0x00, 0x00, EM_DATA_LEN1}, // last number is 16-bit words wanted from the start register address 0x0000
modbus_em_data2[] = {MADDR, READ_HOLDING_REGISTERS, 0x05, 0x00, 0x00, EM_DATA_LEN2}, // last number is 16-bit words wanted from the start register address 0x0500
modbus_em_serial[] = {MADDR, READ_HOLDING_REGISTERS, 0x50, 0x00, 0x00, SERIAL_DATA_LEN}, // last number is 16-bit words wanted from the start register address 0x5000
modbus_em_config[] = {MADDR, WRITE_SINGLE_REGISTER, 0x10, 0x02, 0x00, 0x00}, // System configuration, Value 0 = ?3P? (3-phase with neutral)
modbus_em_passwd[] = {MADDR, WRITE_SINGLE_REGISTER, 0x10, 0x00, 0x00, 0x00}, // Password configuration, set to no password = 0
modbus_em_light[] = {MADDR, WRITE_SINGLE_REGISTER, 0x16, 0x04, 0x00, 0x05}, // back-light timeout, 5 min
// receive frames prototypes for received data checking
em_id[] = {MADDR, READ_HOLDING_REGISTERS, 0x00, 0x00, 0x00, 0x00, 0x00},
em_version[] = {MADDR, READ_HOLDING_REGISTERS, 0x00, 0x00, 0x00, 0x00, 0x00},
em_data1[(EM_DATA_LEN1 * 2) + 5] = {MADDR, READ_HOLDING_REGISTERS, 0x00}, // number of 16-bit words returned, IN BYTES
em_data2[(EM_DATA_LEN2 * 2) + 5] = {MADDR, READ_HOLDING_REGISTERS, 0x00}, // number of 16-bit words returned, IN BYTES
em_serial[(SERIAL_DATA_LEN * 2) + 5] = {MADDR, READ_HOLDING_REGISTERS, 0x00}, // number of 16-bit words returned, IN BYTES
em_config[] = {MADDR, WRITE_SINGLE_REGISTER, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
em_passwd[] = {MADDR, WRITE_SINGLE_REGISTER, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
em_light[] = {MADDR, WRITE_SINGLE_REGISTER, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
 * add the required CRC bytes to a MODBUS message
static uint16_t modbus_rtu_send_msg_crc(volatile uint8_t *req, uint16_t req_length)
    uint16_t crc;
    crc = crc16(req, req_length);
    req[req_length++] = crc >> (uint16_t) 8;
    req[req_length++] = crc & 0x00FF;
    return req_length;
 * constructs a properly formatted RTU message with CRC from a program memory array to the data memory array buffer
uint16_t modbus_rtu_send_msg(void *cc_buffer, const void *modbus_cc_mode, uint16_t req_length)
    memcpy((void*) cc_buffer, (const void *) modbus_cc_mode, req_length);
     * add the CRC and increase message size by two bytes for the CRC16
    return modbus_rtu_send_msg_crc((volatile uint8_t *) cc_buffer, req_length);
 * calculate a CRC16 from the data buffer
uint16_t crc16(volatile uint8_t *buffer, uint16_t buffer_length)
    uint8_t crc_hi = 0xFF; /* high CRC byte initialized */
    uint8_t crc_lo = 0xFF; /* low CRC byte initialized */
    uint8_t i; /* will index into CRC lookup */
    uint16_t crc16t;
    /* pass through message buffer */
    while (buffer_length--) {
        i = crc_hi ^ *buffer++; /* calculate the CRC  */
        crc_hi = crc_lo ^ table_crc_hi[i];
        crc_lo = table_crc_lo[i];
    crc16t = (uint16_t) crc_hi << (uint16_t) 8 | (uint16_t) crc_lo;
    return crc16t;
 * helper functions
 * received CRC16 bytes from client
uint16_t crc16_receive(const C_data * client, volatile uint8_t *cc_buffer)
    uint16_t crc16r;
    crc16r = ((uint16_t) cc_buffer[client->req_length - 2] << (uint16_t) 8) | ((uint16_t) cc_buffer[client->req_length - 1] & 0x00ff);
    return crc16r;
void log_crc_error(const uint16_t c_crc, const uint16_t c_crc_rec)
    M.crc_calc = c_crc;
    M.crc_data = c_crc_rec;
    M.crc_error++;
    M.error++;
     * fake good received bytes from client
     * a null string when not debugging
#define    DBUG_R    //    true ||
static bool modbus_read_check(C_data * client, bool* cstate, const uint16_t rec_length, void (* DataHandler)(void))
    uint16_t c_crc, c_crc_rec;
#ifdef    MB_EM540
    client->req_length = rec_length;
    if (DBUG_R((M.recv_count >= client->req_length) && (cc_buffer[0] == MADDR) && (cc_buffer[1] == READ_HOLDING_REGISTERS))) {
        c_crc = crc16(cc_buffer, client->req_length - 2);
        c_crc_rec = crc16_receive(client, cc_buffer);
#ifdef CRC_ERRORS
        client->c_crc = c_crc;
        client->c_crc_rec = c_crc_rec;
        client->c_crc_length = M.recv_count;
#endif
        if (DBUG_R c_crc == c_crc_rec) {
            client->data_ok = true;
            *cstate = true;
             * move from receive buffer to data structure and munge the data into the correct local 32-bit format from MODBUS client
            DataHandler();
            client->data_prev = client->data_count;
            client->data_count++;
            MM_ERROR_C;
        } else {
            MM_ERROR_C;
            *cstate = false;
            client->data_ok = false;
            log_crc_error(c_crc, c_crc_rec);
        client->cstate = CLEAR;
    } else {
        if (get_500hz(false) >= RDELAY) {
            MM_ERROR_C;
            client->mcmd = G_ID;
            M.to_error++;
            M.error++;
#endif
    return *cstate;
client->req_length = modbus_rtu_send_msg((void*) cc_buffer_tx, (const void *) modbus_em_version, sizeof(modbus_em_version));
             * check received response data for size and format for each command sent
            switch (client->modbus_command) {
            case G_LIGHT: // check for controller back-light codes
                modbus_write_check(client, &client->light_ok, sizeof(em_light));
                break;
            case G_PASSWD: // check for controller password codes
                modbus_write_check(client, &client->passwd_ok, sizeof(em_passwd));
                break;
            case G_CONFIG: // check for controller configuration codes
                modbus_write_check(client, &client->config_ok, sizeof(em_config));
                break;
            case G_DATA1: // check for controller data1 codes
                modbus_read_check(client, &client->data_ok, sizeof(em_data1), em_data_handler);
                break;
            case G_DATA2: // check for controller data2 codes
                modbus_read_check(client, &client->data_ok, sizeof(em_data2), emt_data_handler);
                break;
            case G_VERSION: // check for controller EM540 firmware codes
                modbus_read_check(client, &client->version_ok, sizeof(em_version), emv_data_handler);
                break;
            case G_SERIAL: // check for controller EM540 serial codes
                modbus_read_check(client, &client->serial_ok, sizeof(em_serial), ems_data_handler);
                break;
            case G_ID: // check for client module type
            default:
                modbus_read_id_check(client, &client->id_ok, sizeof(em_id));
                break;
        break;
    default:
        break;
https://github.com/nsaspook/mqtt_comedi/blob/opifixes/Q84/bmc_slave.X/modbus_master.h
https://github.com/nsaspook/mqtt_comedi/blob/opifixes/Q84/bmc_slave.X/modbus_master.c
https://github.com/nsaspook/mqtt_comedi/tree/opifixes/Q84/bmc_slave.X
John P
Joined Oct 14, 2008
2,068
Something off the internet, maybe useful:
1. CRC-16/CCITT (Standard)
Uses polynomial 0x1021 and initial value 0xFFFF. This is common in Modbus RTU and XMODEM.
Code:
uint16_t crc16_ccitt(const uint8_t *data, size_t length) {
    uint16_t crc = 0xFFFF; // Initial value
    for (size_t i = 0; i < length; i++) {
        crc ^= (data[i] << 8);
        for (int j = 0; j < 8; j++) {
            if (crc & 0x8000)
                crc = (crc << 1) ^ 0x1021;
            else
                crc <<= 1;
    return crc;
Code:
            if (crc & 0x8000)
            else
                crc <<= 1;
    return crc;
Basically the same as mine but mine above uses a precomputed 8-bit table and 8-bit computations, so it's usually faster on a 8-bit pic controller.
