panic mode
- Joined Oct 10, 2011
- 4,979
note that all tools need to be grounded, not just the soldering iron.
a while ago i run into an issue and it turned out that the tweezer was occasionally zapping components. it was a curved tip stainless steel tool but with the painted handle with ESD printed on it... but ... the paint was an insulator so having wrist strap did not help. so every now and then tweezer was placed on the desk rather than on ESD matt. even slight dragging/sliding across the wooden desk surface was enough to charge it. after finding out what was the issue, i got large mat to cover entire surface of the desk. same goes for the solder wire, spool is grounded and if i am using just a piece, an alligator clip is attached to the end.
also check resistance of packaging of the ESD sensitive components. parts sliding out of the bag or tube are building static charge due to friction. if the conductivity of the packaging is not low enough this is an issue. this is why anything used for transport/moving need to be ESD safe too. rolling carts may be metal but are the wheels ESD safe? drag chains do help but they are not very reliable if the the conductivity of floor is decent. continuous wire is always a better solution.
