Edit: now sorted guys
Art
Art
sorry to be a hassle could you explain that again? Why would changing R12 have an effect on the transistor?Beside you come short current beside transistor. The low voltage of the feeding the opa-amp is Got (DC current transfer ratio min=20% Typ=50%). There is two ways of the improvement:
1. Reduce current of the consumption R12=1kOhm
2. Enlarge the current of management
Forgive for my English.
hi thanks for your explanation, with this circuit I do not have a GND anywhere could you suggest what I could do then?By "cell" I assume you mean battery. If so, using a reference designator is "C" is confusing. I suggest "B".
When a circuit turns on its FETs, those FETs short out the power to the circuit.
To inure an optocoupler from random action, connect the base pin to GND with a 1 M resistor.
ak
and yes sorry I meant a batteryBy "cell" I assume you mean battery. If so, using a reference designator is "C" is confusing. I suggest "B".
ak
The emitter will work, pin 6 to pin 4.hi thanks for your explanation, with this circuit I do not have a GND anywhere could you suggest what I could do then?
yep definitley at 0,I see no obvious way the opto can turn on with no input.
Are you sure the opto is actually turning on when it shouldn't?
Is its input at 0V?
There is only in theory 5V at the emitter of the BJT part of the optocoupler but for some reason there is approximatley an equal voltage at the collector also turning on the op-amp and then also turn on the FET's which I don't wantI see no obvious way the opto can turn on with no input.
Is its input at 0V?
sorry what do you mean by static current? Is this something I can find out from a datasheet?If the opto Vce is near 0 V and the LED current is 0 mA, then the opto might have failed. At less than 10 mA, the drive current is a bit light. What is the static current of the opamp?
ak
Can you provide any suggestions of how I can improve the circuit would you select a different opto then?If the opto Vce is near 0 V and the LED current is 0 mA, then the opto might have failed. At less than 10 mA, the drive current is a bit light. What is the static current of the opamp?
ak
I think it is TSV621What op amp are you using?
I could find no info on a TSU621.
I have added the resistor as suggested after adding it there is now a voltage present at the base of the optocoupler and they are still turning on.start with one cell and one circuit only. Verify what is going on, then add a 1meg resistor between pins 4 an 6 of the opto like others have suggested to keep it off.
Come back with the results.
yes nothing on the diode endDid you completely disconnect the diode of the opto?
