Error simulating LM5155 boost convertor in LTspice
Status
Not open for further replies.
ericgibbs
Joined Jan 29, 2010
21,584
hi gok.
It is not a device I am familiar with, but I could check out your calculations, against the datasheet, if you post your calculations.
E
BTW: I do have the datasheet,
ericgibbs
Joined Jan 29, 2010
21,584
hi
OK,
What is concerning me is that we are not 100% sure that we have viable working LM5155 model.
I have been searching for a known working circuit example which we could simulate.
This would prove the LM5155 model.
Do you have a known working circuit to post.?
E
Has somebody achieved a valid LTSpice model for LM5155 or already knows how to modify the PSPice original one to make it works on LTSpice?
Thanks in advance
eetech00
Joined Jun 8, 2013
4,728
Thanks in advance
Hi
Yes. I have modified the model for LTspice.
I have included a WinBench Design for a Boost converter 10-12v input to 24v@2A output
Files attached.
See below.
The SS parameter now works.
Slow start enabled:
Slow start disabled:
I know this is an old post, but the LM5155 will not support 180v boost output.
Thanks so much for providing a working LTSpice model for LM5155. So much of what was on this thread previously did not work. Now that I have that, I will try to get working something like this which should be good for 180V or higher output.
Status
