I'm trying to build a DIY simple laser driver with DAC 0-3.3V gain control over the LD, with modulation from Function generator.
In LTSpice everything seems to work OK, but when I built the PCB in real life I ran into unexpected behaviors that honestly didn't succeeded to analyze.
Could you please look in the schematics and try to identify what's wrong?
Simulation graph images shows current flows through the LD, which in simulation is indeed acting as expected
Thank you!
Thank you!
