So, recently i have been trying to import IR2110 driver IC for simulation, i found this PSPICE model from the infineon website, i did the following steps, i) open the .lib file of the component in LTspice ii) click on .SUBCKT and "create symbol" option but when i get all the connections right, i get this below error, i tried googling for this error, but by far there has been no straightforward answer. I get that this error is due to undefined number of pins on the symbol and the .lib file, but i check the .lib file and compared, and there were no mismatch in the number of pins, the symbol still has 11 pins, as it was generated from the software itself, using the library. Looking forward for help. Thank you.
