Epitaxial transistor?
MBG
Joined Jan 30, 2022
23
What is an epitaxial transistor? I have a simple circuit that calls for a 2SD669A and it's referred to as that. Is it anything special or can I substitute one of my run of the mill 2N3904 that I have a million of ? (I'm guessing I can).
The circuit simply applies .5V output (from a ham xcvr, on transmit) to the collector and the emitter is grounded, then a 10K on the base to ground and another 10K on the base to an output which gives a high/low for transmit on/off. -- thanks
SamR
Joined Mar 19, 2019
5,535
Google is your friend " epitaxial transistor / (ˌɛpɪˈtæksɪəl) / noun a transistor made by depositing a thin pure layer of semiconductor material (epitaxial layer) onto a crystalline support by epitaxy. The layer acts as one of the electrode regions, usually the collector". Basically, it is how modern transistors are made... So, yes, you can.
dl324
Joined Mar 30, 2015
18,465
It refers to how the transistor was constructed. Epitaxial is the same as planar.
From TI Power Semiconductor Databook, first edition:
The 2SD transistor is a power transistor. 2N3904 won't be a good substitution.
