Engine Start/Stop Button needs Help!!!
Khaleef
Joined Mar 22, 2017
120
That's strange. One would expect that any failure in the pushbutton would completely disable it for starting and stopping. Maybe the circuit at the generator side tolerates a higher resistance on the pads for stopping, but not for starting, or something like that.
You can probably try to activate the switch contacts with something else, like a piece of wire. To see if the generator starts, but probably the engineer should be the one doing that.
I am very surprised too. The engineer don't have time for these back and forth testing. Since he found the fault with the Button, he either wants to replace it. I am doing all these because I got little idea of electronic stuffs.
dendad
Joined Feb 20, 2016
4,641
Just a couple of thoughts...
It may not be the buttons as it looks to be just all 4 in parallel, and they work for off.
Also, have you tried holding the button down for a time to start it?
Khaleef
Joined Mar 22, 2017
120
Thanks to everyone. I have given up on this button and found a way to install a small push button somewhere on the gen to connect the start wires. So I'll use a different button for start and use the main switch to stop the engine.
Thanks to all for your contributions.
Khaleef
Joined Mar 22, 2017
120
Hello people, I would need a little more assistance.
So my gen now uses an improvised button to start and the Main button to stop but the 2 START wires that connects to turn the engine on are the same switch wires on the Conductive Rubber switch that STOPS the gen. When installing the START button, i noticed after turning on the engine and while it's working, If I try to push the START button again, the Kickstarter makes a kinda sharp noise but the the engine would stop if I press the Main button to shut it off.
Now I'm hoping to get a 2ch remote to see if I can remotely turn on and off the gen. I have looked out so many on AliExpress, as that's the easiest place I can buy things and get them.
I want to know if this would work and what I should check out for in the description of the remote I am looking to get. I would also appreciate inks to the rigth item to purchase that would work.
Thanks.
LesJones
Joined Jan 8, 2017
4,543
I think there is a fault in the stop/start electronics of the generator as there should be an interlock to prevent the starter motor from working when the engine is running. I suspect the same fault probably prevented the original start switch from working. (There is probably nothing wrong with the original switch.) Can you post a schematic of the generator control wiring including the schematics of any circuit boards that are part of it.
Les.
Khaleef
Joined Mar 22, 2017
120
Les.
Getting the wiring diagram would be difficult I think, I'm trying to check if I can find it online. It's a Thermocool TEC Generator Optima Series.
On another brand new generator, it uses the key start ignition type, I tried turning the key when the generator is running, it gave the same sharp sound like the one I stated above.
