I'm working on understanding a balance and battery management board to inject control via arduino. I've succeeded taking control at a couple points, but need to verify that balancing is unaffected.
I've got three of these boards, and they all have "5363" chips at the location marked by the arrow. Each board has a different letter suffix, but all chips on one board share the same suffix. They include "E" "V" and "P". Each cell (10 in series) has it's own 5363, which connects to a transistor to drain current over a 150 ohm resistor to achieve a target voltage. The 5363 also has two separate outputs to two strings of optoisolators (other side of board). One string of optoisolators conveys a "good to discharge" and powers the gate on three output power mosfets. The other optoisolator string conveys "good to charge" and triggers the gate on a single charger input mosfet.
The datasheet has eluded me so far, and I've searched all 6 pin battery management ICs on Digikey, checked through the stickied cross references, and googled it to no end. I'm presuming there are internally set thresholds for low voltage, balance target, and over voltage in the datasheet.
