Elna electronic sewing machine control
tinkerman
Joined Jul 22, 2012
151
Can someone perhaps help to identify a transistor?? in the control circuit. I have a circuit worked out, correctly I hope, but the single transistor on the board which controls the current to the motor has NO MARKINGS!! The part is perfectly functional but one capacitor on the board had failed causing the motor to run continually without the foot control depressed. Got everything back to normal but would like to go further with the design.
Would upload a schematic but can't see how to do it. :(
tinkerman
Joined Jul 22, 2012
151
See the 'Upload file' next to Post Reply.
Max.
Thanks Max. Here is my sketch. Hopefully it is correct. Q1 is NOT and NPN transistor it seems from diode tests with a multimeter. It had a red dot on the top of the can. That's all. :( I can provide photos of the board top and foil side if that helps.
tinkerman
Joined Jul 22, 2012
151
I don’t think triac. Needs a diac as I understand it. SCR never thought of that. There is a diode D1 so motor received only positive pulses. This machine is 1968 vintage.
28,272
Yes, the device could be an SCR, a bit more likely in 1968. but an NPN transistor would also be able to work. and my guess is that the capacitor that failed was C1, and that it failed with either high leakage or a short circuit.
tinkerman
Joined Jul 22, 2012
151
No turned out it was the electrolytic C2 that had failed. 20uF 16V. First thing I tried was an 1A NPN transistor but it heated almost immediately. So then I changed capacitors. I've never seen a SCR circuit before without a diode in the gate. Didn't cross my mind. I think I'll bread board a circuit like it with a SCR and see how that turns out.
pfofit
Joined Nov 29, 2006
57
Is R6, R11, R12, R13, C12, and the zener all connected together?
Is the emitter connected to the common line and L1 or just to L1?
Could you put dots on the intersecting lines of your diagram. I like dots. :)
You have a T2 designation at the top and bottom.
What is the voltage/ waveform across C2 without touching the foot pedal?
Can you post a pic of the board?
Is there a label on the motor?
thanks
28,272
More likely a Triac, a SCR is uni-directional.
Max.
Yes, an SCR is indeed unidirectional, and looking at the circuit, if it is correct, there is also a unidirectional diode just upstream from the device. I am not certain why it is placed there, but that is what I see.
And if the part that failed was that capacitor C2, then yes, an SCR is likely. Sort of a different type of circuit, but nothing unbelievable.
And now, after seeing the waveform, it is more likely an SCR, although a triac would explain the waveform, if D1 is not really a diode.
And D2, shown as a zener diode, seems to be serving the same purpose as a diac would serve.
MaxHeadRoom
Joined Jul 18, 2013
30,808
The only problem is if a SCR then you are not getting full wave AC to the Universal motor.
If SCR I would expect a bridge before it in order to switch each half cycle and run the motor on DC this way.
Logically the circuit shown would be an Triac.
Max.
I know that this is an old thread, but since this is the only Internet search hit for a schematic of this device, I thought it might be useful to add my findings to this thread in case it helps future searchers.
I think that the original poster's schematic has a few errors or else the circuit I have is different. I am attaching the schematic of the device that I have which has the same model number (447300). The differences are:
- There are two screw terminal connections labelled T2 - I assign T1 to the bottom one.
- D1 is out of place - it connects T2 to R12 and foot control switches common.
- R8 and anode of Q1 (collector in original) connect to R1 and the first foot control contact.
- R13 and R7 values are swapped.
- R10 is 10K not 1K.
- C2 is 22uF not 20uF.
I have attached a schematic of my reverse engineering results with component annotations made to match the schematic from the original poster. I have also attached images of the PCB.
From my waveform observations, the circuit is only switching positive half cycles as predicted, but with the speed selector in the "+" position, the full speed switch bypasses the circuit to give the full AC waveform.
Andy
Hi Andy, did you ever find out what type of Transistor Q1 was as I also have the same foot controller. And I would be interested
if you ever got the Elna foot controller working.???
Thanks Anthony
rwsell
Joined May 23, 2020
Thanks Anthony
Hi Anthony, I have two of those 447300-1 Elna foot pedals. Only one works correctly.
I believe the semiconductor on the boards is a SCR. I do not know the part number, it has no markings.
andymiller53 's drawing is very useful but it is for the board marked TA 231 on the printed wiring
side. My defective board is marked TA 230. The components soldered to the board are very
similar and almost located the same but the printed wiring and rotation of the SCR's
are different.
I have spent an incredible number of hours on this project but the best I have been able to
accomplish is to slow the motor down to a single speed (it originally started running at a high
speed as soon as the power cord was plugged in).
I have tried 3 different SCRs and just recently found and replaced two defective resistors (R7 and R13
on Andy's drawing).
I do not understand the difference between NTE SCRs that are described as sensitive gate and those
that are not.
I am hopeful that someone on this thread can help me!
Thanks, Russell
I drew a schematic of newer Elna Air, they are an oddball circuit. Thanks for fixing those sch errors.
The term "sensitive gate" can be a huge variety of different gate trigger current. This looks to be an SCR circuit, with the steady DC control voltage at the gate and rectifier diode to the motor. Original would be a TO-5 or TO-39 case very sensitive-gate 0.2mA thyristor, which is an old, rare bird and long obsolete and expensive.
You would use a modern TO-220 case (insulated tab) part with added small heatsink.
I would use TS820-600FP (8A 600V 0.2mA plastic insulated) or S6008LS3TP. A TIC106D, MCR8SMG would work- but not insulated tab. Note TO-220 pinout is different (KAG) the gate is not the middle pin (so you'd have to shuffle the leads of the new part. TO-5 pinout (KGA).
OLD TO-5 SCR's: 2N2329 400V 1.6A 0.2mA TO-5, NTE5410 600V 3A 0.2mA TO-5, MCR1906-6 400V 1.6A 1mA
I think you can use a light bulb in place of the motor for testing. Make sure the 22uF capacitor and R7, R11 are good, this would also cause the runaway you are seeing. Elna speed controls looked at motor back-EMF to give better speed/load regulation. This made them highly tuned to the motor and SCR.
are different.
on Andy's drawing).
that are not.
Thanks, Russell
Hi Russell I have some information from Canada for you this seems to have all the information for the Elna foot controller and all the components on the board. I only received this today Wednesday 3/6/20. Thanks Anthony
