electronics equation question
scoundrel421
Joined Oct 8, 2018
5
I know this equation (f=1/3.3RC) is an Oscillator Frequency equation; just wondering where the '3.3' came/derived from. NOTHING I have studied thus far used that figure as a Constant...any ideas?
OBW0549
Joined Mar 2, 2015
3,566
Don't feel bad; I've been "doing electronics" since the late 1950's and I've never seen it either.
My guess: it's probably specific to a particular integrated circuit oscillator, and not applicable to anything else.
scoundrel421
Joined Oct 8, 2018
5
Most likely, that is the case. I ran into the equation in a practical exercise; it posed no problems in solving it, but I just didn't understand where the figure used as the constant came from or was derived from. The practical exercise was building and testing an oscillator for a logic probe, and that formula was for calculating the frequency of the oscillator with particular variables, i.e., the resistance (R) and capacitance (C) values
34,807
As a general rule of thumb, we know that tau = RC.
For a first order filter 2πf = 1/RC,
or f = 1/6.3RC
If you check the application notes of various timing circuits you will find variations on the xRC theme.
The period can be xRC where x can be anything from 1 to 6 depending on the switching thresholds of the oscillatory circuit.
The devil is in the details of the circuit.
scoundrel421
Joined Oct 8, 2018
5
Something about a phase shift resonant frequency struck me when I saw it.
I thought of Phase differences, too; but there wasn't anything explained/mentioned about what '3.3' represented, other than a constant of some sort...and I kinda guessed at that, too, with no real way of checking if I was right...all I know is that I had no problem doing the math and making the equation work, and having it make sense to me
danadak
Joined Mar 10, 2018
4,057
Not sure why they got this result but -
Maybe its a composite factor derived from phase shift and Tpd of inverter
and non symmetric inverter thresholds, but then at low freq Tpd must be
irrelevant.
Regards, Dana.
27,507
For a number of devices there are special formulas for the time constant with that particular device. two that come to mind right away are the CD4047 one-shot IC and the 555 timer IC. In addition, there are some circuits where a specific RC time constant formula applies because of the trigger voltages in that specific circuit.
So the formula you present would only apply to a very specific instance.
ebp
Joined Feb 8, 2018
2,332
60 degree phase shift occurs at 1/3.63RC Hz
The circuit at #7 is not a conventional buffered phase shift oscillator. It is a string of discrete time delays using (usually) CMOS inverters and can be built with any odd number of stages. The waveforms will depend on the time delay of each stage and the number of stages. An unbuffered CMOS inverter will typically switch at half of Vcc, but the gain isn't especially high and the output transitions won't be fast, so with very small RCs the outputs may spend more time slewing than sitting at a rail. Once the RC gets sufficiently great, each output will become more square and swing rail to rail. If the number of stages built that way is large enough, peak to peak voltage on each capacitor will get close to being rail to rail, which of course means the delay of the stage is longer because the cap voltage has to swing farther to cross the switching threshold. Schmitt trigger inverters can be used and the delay times will be quite different for the same RC values. A Schmitt based circuit will reliably oscillate with a single stage, a simple inverter probably won't. The RC values don't need to be the same for each stage.
scoundrel421
Joined Oct 8, 2018
5
It's a phase-shift oscillator.
The frequency of oscillation is where the phase-shift of each RC LPF is 180°/3 = 60°, (for a total feedback phase of 360° ) and that occurs at a frequency of 1/3.3RC.
Note that the bottom of the capacitors must all go to ground.
THAT is exactly what I was thinking it may have been; I was just having some trouble explaining it to myself...it now makes Perfect Sense; now, Life Can Go On, and the world can start turning again *lol*...Thank You for the explanation
