If you look at your circuit in real life circumstance, then key A should be door closed, and key B should be driver seated, otherwise, if the driver gets in the car and gets back out, and shuts the door, then already 2 inputs have been satisfied, so now the circuit is activated to that point, especially if the window was down for hoim to put the key into the ignition...and so on...
but making the door shut be key A then if the driver sits down, and gets back up out of trhe car, then the switch is released and no output happens at the first gate. Until he sits down again...
And so on...
Now if this really had to be designed, then a fail safe network would need to be implemented for every possible scenario. such as a reset when the driver gets out of the seat, or else he will now be able to start the car with the door opened, so a reset would need to be in the first order of the branch, such that if he gets back out, then the switch would activate a reset and so on ....
Also another reset should activate when both, the ignition is turned off, and the door is opened AND then shut.
Just one more thing yet, you would get a good grade on this if you designed it to take into consideration as much failsafe features possible.
Look at every scenario, of switch inputs and design it to work in proper sequence every time.
That wouild be using logic gating to call the reset inputs as well.
Are you getting an understanding of logic networking with this, now, with these examples?
And so on...
