FYIDave, what are the errors? I've protected the documents from alteration, leaving users to view or print. I might be able to adjust some of the parameters on Acrobat 8 so 7.0 users wont have as much problems.
Thanks. Nothing serious. It should encourage people to update Adobe Acrobat. There was a serious security flaw with v7.0.FYI
Dave
You can update to v7.0.9 (instead of installing v8) to patch the security flaw discovered in v7.Thanks. Nothing serious. It should encourage people to update Adobe Acrobat. There was a serious security flaw with v7.0.
Make sure you right click and select "Save Link As" and save it to your hard drive first, and make sure you have the most up-to-date version of Acrobat Reader.TKS, but when I open these two files, the acobat tells me that when opening the document, some erros happen! and the document can't not be recoveried!
This is a typicl problem with downloading PDFs from the web using Acrobat Reader v6. As m4yh3m says, update to the latest version (v8) or version 7.0.9 at least.TKS, but when I open these two files, the acobat tells me that when opening the document, some erros happen! and the document can't not be recoveried!
Which version of Adobe Reader are you using? (That's if indeed you are using Adobe Reader).Error in opening the attached pdf files. plz resolve it ASAP.
Regards,
Riyaz Shaikh
riyazshaikh16in@yahoo.co.in
Sorry that you're having issues. Given that m4yh3m who created the PDFs stated that the latest version of Adobe Reader must be used, we can only recommend that. We don't know what software was used to create them, so cannot offer advice further than that.not to be a pill but, so you know, i'm using Evince 0.8.1 as my native .pdf viewer in Ubuntu 7.04 (Feisty) and the .pdf documents require a password before they can be opened both downloaded to my HDD or opened from the site.
Adobe Acrobat v8.0 was used to create the files. They are restricted to viewing and printing only, with a password put in place to keep people from modifying and redistributing the material. You can download Adobe Acrobat Reader for linux from Adobe's website.Sorry that you're having issues. Given that m4yh3m who created the PDFs stated that the latest version of Adobe Reader must be used, we can only recommend that. We don't know what software was used to create them, so cannot offer advice further than that.
I might be able to do a screen dump from my version of Adobe if you like. I can upload it as a JPG. Let me know and I'll see what I can do.
Dave
For a 3-input XOR or XNOR gate the outputs for A, B, and C being high is as shown in the the cheat sheet. See this thread from a while back which discusses it in detail and explains the "rules" behind the function of XOR (and consequently XNOR).I may well be wrong, but I think there is an error in the Logic sheet - the three input XOR and XNOR gates. When A B C are all high on an XOR gate, Y should be low. Likewise on an XNOR gate, Y should be high.
This is reflected in the 'function' part- it should read
Y = /A./B.C + /A.B./C + A./B./C for an XOR gate
Y = /A.B.C + A./B.C + A.B./C for an XNOR gate.
Unless it is too late for me and my brain is getting fuzzy??
And to echo the thoughts of many others, these are a great resource- thanks m4yh3m for putting this up.
In particular, see this reply: http://forum.allaboutcircuits.com/showpost.php?p=51043&postcount=12I may well be wrong, but I think there is an error in the Logic sheet - the three input XOR and XNOR gates. When A B C are all high on an XOR gate, Y should be low. Likewise on an XNOR gate, Y should be high.
by Don Wilcher
