I'm tempted to say "you're getting warm"
Sadly, it seems rather more a case of phronemophobiaFrom this page: https://en.wikipedia.org/wiki/Learning_disability
we have "dyscalculia". Could it be?
That's great if 'working on it' means something more than merely searching for the answer...
While the 'ports' may be pure resistive --- resistive networks cannot truly transform impedance...Ok, i am starting KCL and KVL
in this circuit how the direction has taken??
While Kirchhoff's laws form a useful frame of reference -- apprehension of the problem at hand (i.e. post #113) requires your attention to the implications of positive and negative reactance/impedance (as illustrated in post #145) -- That said: Generalization of Kirchhoff's laws (and of fundamental electrical relations) so as to 'embrace' said implications may be very useful indeed!I am moving back to KVL and KCL
please help me to find this current in it..
How to do ?apprehension of the problem at hand (i.e. post #113) requires your attention to the implications of positive and negative reactance/impedance
You were on the right track in posts #239 and #241 --- Moreover you should study post #145 until you thoroughly understand it...How to do ?
I say HP was giving the _velvet glove_ when she saidHow to do ?
Now I'm giving _knock out punch_ by sayingSystem Quality Factor (Q) = √(transformation_ratio-1)
According to 145@RRITESH KAKKAR
It occurs to me that the 'block' you seem to be experiencing with the current exercise may owe to misapprehension as regards impedance transformation via networks (arrangements) of discrete reactors...
Here I present an example of transformation of 10v to over 60V via a series resonant RLC circuit --- While not directly applicable to the exercise, this is intended to set you upon the right path!
Note that, with some qualification, impedance may be thought of as EMF to current ratio!
Please note that following is not to be confused with other impedance transformation schemes/phenomena (i.e. mutual inductance, 'buck/boost', etc...)
I hope you find this helpful!!!
Within the confines of this discussion, resonance is a condition wherein 'opposite' reactor types exhibit reactances of equal magnitude but opposite sign and, hence, 'cancel' -- Below is a representation of a series RLC circuit at resonance -- Please consider the following:
Because EMF lags current by 90° in a purely reactive, net capacitive circuit, capacitive reactance is said to be negative.
Because EMF leads current by 90° in a purely reactive, net inductive circuit, inductive reactance is said to be positive.
With reference to the below attached schematic:
Reactor 1 (The capacitor) exhibits a reactance of -2πΩ @ a frequency of 100MHz
Reactor 2 (The inductor) exhibits a reactance of 2πΩ @ a frequency of 100MHz
Hence the circuit is said to be resonant @ 100MHz
Owing to their series connection, the net reactance = the sum of the reactances = 0Ω. Thus the net impedance = the value of R = 1Ω
Thus it is that the current through the circuit is determined by the EMF of the power supply (1oV Peak) and the resistance of R (1Ω) → 10V (Peak)/1Ω= 10A (Peak)
Ohm's law tells us that the EMF across a pure reactance = I*X = 10A*2π ≈ 62.83V in the case of the inductor --- And 10A*2π ≈ -62.83V in the case of the capacitor (note that the signs indicate the respective phase shifts)
In theory any finite transformation ratio is possible via proper choice of the reactors and the resistor.
Illustration of a series RLC circuit at resonance -- Post continued below image...
As an aside please consider a parallel resonant circuit.
Via the technique of calculating the equivalent value of paralleled resistors or pure reactances:
1/(1/Xc+1/Xl)=Xnet but since Xc=-Xl at resonance: 1/(1/-x + 1/x) = 1/(0/x^2)=1/0 = ∞ (For these purposes)
Thus we see that a parallel LC circuit at resonance presents as an 'open circuit'
Again, hope to have been of help!
Best regards
HP![]()
Q is proportion of reactance to resistance so like Qp=R/X and Qs=X/R. Now I am saying answer is the 800 lbs gorilla riding elephant through room!
I am same generation as you so is appropriate for me to say get with it dude!
Ok I'll walk you through it again...According to 145
There is 10V sinwave source of 10A??
by applying the AC voltage to inuctor it give back EMF which is absorb by Capacitor?
Why you have place RLC circuit across 10V Sinwave
No! No! no! no!!! ---- please read the postby applying the AC voltage to inuctor it give back EMF which is absorb by Capacitor?
Best regardsPlease note that following is not to be confused with other impedance transformation schemes/phenomena (i.e. mutual inductance, 'buck/boost', etc...)
How?Each reactor exhibits a reactance having a magnitude exactly = 2πΩ
The inductor exhibits an inductance of 10nH -- So:How?
it is 2πFC and 1/2πFL
Where is F and C
Designing a Robust Comparator Timer | Digital Design | 0 | |
Question,help with sinusoidal voltage | Homework Help | 17 | |
| M | OP amp question. Calculate the gain vi/vo. | Homework Help | 1 | |
A electronic circuit question ! | General Electronics Chat | 30 | |
An Electronic Welder Circuit Question | General Electronics Chat | 3 |
