Electromagnet triggering fuse
JP123
Joined Feb 23, 2017
9
Im running an electromagnet straight to a power supply which is providing 12v, my electromagnet is gauge 0.8 and has 128 turns. For some reason when I power on the supply it’s powers for a few seconds until the fuse kicks in. Would I need a resistor? If so how many ohm’s?
ericgibbs
Joined Jan 29, 2010
21,649
hi JP,
Welcome to AAC.
Have you measured the resistance of the magnet coil.?
What is your power supply current rating at 12v.?
E
JP123
Joined Feb 23, 2017
9
ericgibbs
Joined Jan 29, 2010
21,649
hi,
With a 0.4R resistance at 12V thats 12v/0.4R = 30Amps!!!!
If you want the maximum current from your 5A supply thats a resistance of 2.4R, so you need a 2R resistor in series with the coil.
The rating of the 2R needs to be greater than 50Watts. == 5*5 * 2R = 50W.
For continuous use a 100W resistor would be advisable.
E
EDIT:
If you could pick up an old 12V vehicle headlamp bulb, rated at 50W that could be used as the resistor.
A lower bulb wattage would be OK, say 24Watt would reduce the load on your power supply, but it would reduce the coil magnetic strength..
BTW: the coil will get hot.!
bertus
Joined Apr 5, 2008
23,031
Or put the powersupply at 2 Volts to stay at 5 A.
Bertus
Kjeldgaard
Joined Apr 7, 2016
475
If the measurement is performed with ordinary two wire instruments, the resistance in the coil is certainly far below the specified 0.4 Ω
ericgibbs
Joined Jan 29, 2010
21,649
hi JP,
It is possible your power supply will not last long running near its current limit.
Give us more details of the power supply and your application.
E
JP123
Joined Feb 23, 2017
9
I couldnt find a lot of information on the power supply as i dont have any manuals.
The site i listed previously is all i know about it.
bertus
Joined Apr 5, 2008
23,031
The power supply seems to be rather crude, as this is the description going with it:
Power Supply, 2-12V AC/DC/5A
The IEC Power Supply is a compact, general purpose power supply to provide
switched AC and DC voltages at 2, 4, 6, 8, 10 and 12V.AC and DC at about 5 to 6A.
The DC output is full wave rectified but not filtered. Made in Australia
Bertus
JP123
Joined Feb 23, 2017
9
It’s going to be used to make a solenoid motor, would it be easier to get a power plug rated at 12v and 1-2 amps rather than getting big resistors? The only reason I’m leaning against it is if the coil won’t be as strong.
38,946
The magnet field of a coil is determined by the ampere-turns (amps times turns).
So if you reduce the current and increase the number of turns with smaller wire, you can still end up with the same magnetic field.
That will save power.
So for example 5A @ 128 turns is the same as 0.5A @ 1280 turns.
JP123
Joined Feb 23, 2017
9
Oh I didn’t know that thanks
dendad
Joined Feb 20, 2016
4,642
Have you thought of using the coil assembly from a 12V relay? Just remove the armature and contacts then you will be left with a good coil.
Just out of interest, it looks like you are in Oz. I'm a couple of hours North of Melbourne.
