Electrolytic Capacitors Connection
Electronic_Maniac
Joined Oct 26, 2017
251
Hi all,
Is it Ok if I connect a E-Cap with its positive terminal to ground and its negative terminal to a negative voltage such that the voltage at the negative voltage is always negative at all times when compared to its positive terminal
profbuxton
Joined Feb 21, 2014
418
Think about it a bit! Pos side is connected to common(ground). Neg side is connected a neg volts with respect to common(ground). What volts polarity appears across cap?
Try it with a resistor if you want to experiment.
