Electrolux Oven Controller Burnet need help about Spade connector
chshahzadali
Joined Aug 22, 2021
Hello!
I want help regarding my Electrolux Oven Controller
It was burnet at heater terminal, and bought new one. Almost $100 :-(
I need to fix one spade connector also but how to select right one. (Load Rating)
I don’t want to spoil this new controller also and want to chose right connector.
Is there a difference between AC spade connector and DC spade connector? How to chose right spade connector for 10-15Amp AC load?
please help.
thanks
MaxHeadRoom
Joined Jul 18, 2013
30,839
You should be able to get those at any decent hardware or automotive supply store.
The same physical size is the important feature.
Ensure a positive crimp in order to prevent heating at the terminal point.
The major problem is crimping. You need the proper tool. There is a tool for insulated wires and one for uninsulated wires. There is a hand crimper and a ratcheting crimper available. There are dies for the wire and the terminal.
That particular terminal looks difficult to crimp.
e.g. https://www.digikey.com/en/products/filter/terminals-quick-connects-quick-disconnect-connectors/392
I;m not saying that this https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1742718-1/4021805 is the right terminal, but my hand crimping tool would probably not be able to crimp it.
The terminal is known as a FASTON terminal.
If the pole of the flag terminal extended further, then I would not have issues.
You could crimp the insulation with the insulation crimper of my tool and solder the wire side.
