KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
If you use RTV, be sure to use the electronic grade that does not leach out acetic acid when curing.
Never used RTV. But I HAVE used Hot Melt Glue (HotSnot). You melt and drag a string of the stuff then put it under the sleeving. When heating and shrinking the sleeving the glue melts and is squeezed into the joint. It also oozes out if you use enough. The excess is easily cleaned away. Doesn't have to cure and can be ready to be worked with in a few minutes.If you use RTV, be sure to use the electronic grade that does not leach out acetic acid when curing.
Wow, you really opened my eyes. You made all sense. Nevertheless, imagine a tape insulates 400V per turn. It would make all sense in the world to advertise "Valid for 230V", or something like that. I understand that most of the time you do more turns, but, I don't know, it would be great to have some kind of printed text on the tape that says a standard insulation data for wiring. For example: 3000V/mm or something like that, so you can compare which materials insulates more.Late chime in here - but aside from holding things together, electrical tape also provides insulation. Insulation can be thought of as a resistor. Layer upon layer of tape is tantamount to resistors in series.
Let me make up some BS numbers: BS because I don't know actual numbers: Suppose a single wrap of electrical tape directly on a copper wire will offer enough resistance to prevent arcing between that wire and ground at - (BS#) 50 volts. Two wraps will prevent arcing at (BS#) 100 volts. Twenty wraps will protect against arcing when 1,000 volts is present on that wire. Again, these numbers are bogus, but probably the reason why electrical tape doesn't specify a "Max Voltage" is because it all depends on how much tape you use. If the tape were to say it can resist 1KV at 20 wraps and I only put 15 wraps, then a spark occurs and then a fire or explosion - who do you think can be blamed?
Maybe there are tapes with voltage ratings on them, I've never seen one. Shrink sleeving is more likely to be voltage rated, but again, application can vary. When working on fuel pumps for C130's it was my job to install shrink sleeving over the length of a pair of wires. The sleeving came in pre-cut lengths and I had to install at least two lengths to cover the entire run. A supervisor told me to pull the sleeving as I shrunk it, thus stretching it. That resulted in using a single piece of sleeving for the full run of wire, but it also left the sleeving pulled thinner. I did that only a few times before coming to some good sense and going back to the way the engineers had planned out the job. This just goes to the adage that if you make something idiot proof, a better idiot will come along.
I think there's a lack of ratings on these things because the user can abuse the installation process and thus give a false sense of security.
Up to about 40 kV in the CRT days. Don;t know the voltage on a bug zapper. Automotive and lawnmower ignition systems (spark plugs). Microwave ovens about 3 kV DC.When do you start to think that the insulation of this electrical tape or thar tube might not be enough? 2000V? Who works in home with 2000V?
if you looked at the PDF I posted, there are specs, but as I said you have to work for them. It's 0.012" thick, so that's 12 mils. It has a dielectric strength of 784 V/mil, so each layer is worth 12 * 875, so 10,500 V. Not bad for one layer of tape.As far as specs on tapes - I've never seen any. Not saying they don't exist, just saying I haven't seen any.
3 phase would not have a difference of instantaneous 380 V when you take into account the phase relationship. The difference to ground you have to worry about. When you have different voltages like 24 V and 230 V, you need to have a physical barrier or make the voltage rating of the cables the same as for the highest voltage.Another question... People in home use 130-230V, may be if you have three phase you can have 380V or so. In all these conditions, is it OK to insulate a cable with electrical tape or tube?
Forget about weird conditions, simply 2 cables with a difference of 380V.
