MaxHeadRoom
- Joined Jul 18, 2013
- 30,661
No such thing, here in Canada anyway.My water heater is on a cheaper off-peak meter - I assumed everyone did that.
Max.
Don't even know what that is, though I can guess.My water heater is on a cheaper off-peak meter - I assumed everyone did that.
Your meter is on your dwelling; any power tapped from the pole is "free".Please keep brainstorming!! I need and answer...what about outside??? The transformer? the wires, the ??? Surges? Can someone highjack power from a pole???
We don't have peak/off-peak in my area... Don't know where the OP lives, but we have what is considered inexpensive electricity and I think we're paying 0.11/KWH.My water heater is on a cheaper off-peak meter - I assumed everyone did that.
In places like the UK, with the installation of storage heating units in various rooms, they would switch on in off peak Hrs during the night, this would store the heat and release it during the day when they would power off, a separate meter would record this lower Kw rate.Don't even know what that is, though I can guess.
Ok, so 1) turn all breakers offSwitch off all of your circuit breakers at the panel and then switch them on one by one noting how much power you're consuming on the utility meter. If you can narrow to a circuit, check each appliance on it using a watt meter. The power company may have one you can borrow. I did that to check power consumption on an old refrigerator. Most people don't clean the radiators on their refrigerators (me included), but that can increase consumption (marginally).
The monitoring of the breakers feels incomplete. When the electrician stands there and hooks up each line and watches for a short time..5 inutes, then moves on. The monitor we put on the furnace line and the dryer line for a couple days felt more complete....am waiting for electrician to come back and do ALL the breakers for a couple days each.You are looking in the wrong place, appliance might be ok but there needs to be somewhere something else that hogs the current.
You might want to look on what is the line voltage at night compared to voltage during the day. Do the lights (incandescent ones) get really bright?
Our meter is digital and I believe they do estimated billing. Could this lead to ever increasing numbers???That's just what I suspected. A similar thing is done in many commercial installations in the U.S.
I think the problem with getting it down into the residential market is that the places that benefit the most would be places that are already heavily built up and, therefore, already have the existing single meter in a huge fraction of the homes. As existing meters are replaced with new remote sense meters, we will probably see tiered and peak/off-peak metering come into play more and more.
Which is why you need to establish a baseline and first see if the meter continues to run even if ALL of the breakers are shut off for an extended period of time, such as overnight or, if possible, a full day.I just feel like getting snipits of reading whether outside on the meter or inside on the breaker/lines is not allowing for real data to be revealing a problem.....I am frustrated beyond belief...I feel like there is a conspiracy...!
Can YOU see what the meter is reading?Our meter is digital and I believe they do estimated billing. Could this lead to ever increasing numbers???
They have the power saver switch, that they install upon request..it is to automatically turn off your a/c during the hottest part of the day I believe. We do not have this installed.
Interesting - the dimming happens in the evening, noticeably the 5 mini bulb chandelier on a dimmer switch. Bulbs around the house when turned on frequently turn on unnaturally bright than burn out.You are looking in the wrong place, appliance might be ok but there needs to be somewhere something else that hogs the current.
It has three or 5 digital bars that show up cumulatively across the top then start over and over, then a kilo number pops up for a second or so then disappears, then pops back with the new usage number. This is what I recorded every hour on the hour for 12 hours. this is when I saw the spikes of kilo's at strange times, not correlating to activities in the house....Can YOU see what the meter is reading?
Does it show just accumulated usage or does it give at least some indication of immediate energy consumption (the old mechanical meters here had a wheel that rotated at a rate proportional to the present average power draw).
So do a similar test but with all of the breakers off. Then do a test with half of the breakers on followed by a test with the other half of them on. This will narrow things down considerable. It is either something before your panel or after and, if after, you will know which half of the breaker panel is the culprit. Once you know that, then repeat the test again with only half of the offending breakers on followed by a test with the other half. This is called a Binary Search and you will be able to narrow it down to a specific breaker (assuming it is being caused by something on a single breaker) after just a few cycles of this testing approach.It has three or 5 digital bars that show up cumulatively across the top then start over and over, then a kilo number pops up for a second or so then disappears, then pops back with the new usage number. This is what I recorded every hour on the hour for 12 hours. this is when I saw the spikes of kilo's at strange times, not correlating to activities in the house....
Alright, I will do it! I will do this, I need to wait a couple of days,,..temps dipping into the 30's tonight and tomorrow...I have little ones in the house!As others have suggested, get you baseline data first. Shut off everything at the break panel -- everything -- and leave it off all night (or, if possible, for an entire 24 hours) and see if your meter shows any usage during that time at all (and, if so, how much). That's your starting point. Until you have done that, you are going to continue chasing your tail.
Got it, I will try this...can't wait!! Oh you have no idea! The thought of figuring this out.....this has become a part time job.Which is why you need to establish a baseline and first see if the meter continues to run even if ALL of the breakers are shut off for an extended period of time, such as overnight or, if possible, a full day.
Either the electricity is flowing through your breakers or it is not. If it is not -- if there is some path that is allowing current to flow through the meter without going through your breaker panel, then you can monitor the currents in your breaker branch circuits till the cows come home and you will never find it.
Another thing you could do is check your monthly KWH usage from a time you thought it was "normal" and then look for when it started trending upward.Got it, I will try this...can't wait!! Oh you have no idea! The thought of figuring this out.....this has become a part time job.
