Electrical insulation for a transformer
Drmario5237
Joined Oct 14, 2018
65
What type of electrical insulation paper would I need for a transformer that has millivolts and milliamps on the primary and no more that a few volts and amps on the secondary with about 1592 kilohertz radio frequicy feeding the primary. Thanks.
Reloadron
Joined Jan 15, 2015
7,962
This sounds like a duplicate post.
If in doubt, use Kapton tape.
Yes, Kapton tape is fine for most general purpose applications. The insulating materials get broken down by class depending on variables like temperature and voltage breakdown so they have insulation classes but again for a basic simple insulator Kapton tape is readily available and common. Kapton is made by Dupont and the name belongs to Dupont.
Ron
DickCappels
Joined Aug 21, 2008
10,661
Is Prespahn what some used to call fishpater?
Any insulating material that does not have a tendency to absorb water should be fine. Your wire is probably insulated, so if ony a few volts you would be find with just the insulation on the wires unless there are some sharp edges (such as square metal cores) involved. Even though I use laser printer paper for home use and Permacel mylar tape other things. Kaptan is expensive so I only use it inhigh stress applications.
