Electrical equivalent circuit
mathilder7
Joined Oct 30, 2018
I have a problem with finding the equivalent circuit to a mass-spring system and can't find the answer to it anywhere. Hopefully someone here can help me. The mass-spring systems relevant for the question are attached as links in this post.
THanks
mathilder7
Joined Oct 30, 2018
I've found some equations for the circuits, but going from mechanical to electrical seems to be worse than i hoped for.
For circuit number 2 I've found this:
ma1 + 3k*x1 - 2k*x2 = 0
2m*a2 + 5k*x2 - 2k*x1 = 0
WBahn
Joined Mar 31, 2012
33,109
Just set up the differential equations for both and match terms. Don't forget to take into account initial conditions, too.
MrAl
Joined Jun 17, 2014
13,780
THanks
Hello there,
Unfortunately both of your drawings might be a little too ambiguous.
Are you saying that there is no damper in either one? That would be unusual but it's up to you. That means whatever happens never stops.
Also, where is the force? Alternately, what are the initial conditions?
