Electrical Circuits Homework
azathioprin
Joined May 5, 2016
2
Firstly hi everyone. I am a student departmant of electrical engineering at ITU. I can not do these questions. Can you help me ? Y represents 7,
So 2y = 2*7 = 14 likewise 8y = 56 , 4y = 28, 10y = 70, 40y = 21020160505_182900-1.jpg 20160505_182910.jpg
MrAl
Joined Jun 17, 2014
13,745
40y=210 ??
You should double check that.
What kind of circuit analysis techniques were you taught so far?
Can you combine impedances for example?
azathioprin
Joined May 5, 2016
2
Sory my fault, 40y = 280
We learned Thevenin, Norton, Node Voltage and Mesh Current analysis methods. We can use Node Voltage method for first question.
Z for R = R ohm
Z for L = jwL ohm Z for 3H inductor, j*314*3=j942
Z for C = -j/wc ohm (there is no capacitor in the question)
We can take the f is 50 hertz on steady state. So, w=2πf = 2*3.14*50 = 314 rad/s
33,021
Since you have (supposedly) learned a number of techniques, then apply those techniques to these circuits. Let's focus on just one problem per thread, so let's focus on the first one and ignore the second one (it should go in a separate thread).
You need to show YOUR best attempt to solve the problem using the techniques you know. Show your work.
Unless you are doing transform methods, using impedances will not help you because (at this point) you probably only know how to use impedances for circuits in sinusoidal steady state while the first problem is a transient response question.
The claim that the circuit is in steady state before the switch is closed is a bit misleading because you have an open-circuited current source, but since we are only interested in what happens to the right of the switch after the switch is closed, we can hold our nose and turn a blind eye to this inconvenient fact.
What is the current in the inductors just before the switch is closed?
What is the current in the inductors just after the switch is closed?
What is the current in the inductors a long time after the switch is closed?
What is the general nature of the current in the inductors after the switch is closed (i.e., what kind of equation describes it)?
MrAl
Joined Jun 17, 2014
13,745
Z for R = R ohm
Quick question:
So you are saying that the 10 amp current source is an AC source (50Hz) and you need to find the AC steady state response? I ask because that is different than the transient response.
33,021
Z for R = R ohm
This post wasn't up when I was writing my earlier response.
So are you saying that the current source is a sinusoidal source?
If so, then can we assume that you have learned transform methods, particularly Laplace?
