I'd try to take a look at one of the commercial units and see how they do it. I suspect a positive-displacement, plunger type pump. Like a syringe. But that's just a hunch.Hi,
I want to use an electric pump to dispense the hand sanitizer gel ...
should I use a type pump that gives me a small amount of gel at a few pulses?
can anyone recommend me some model?
do I see if I find peristaltic dosing pump?
Yes. Peristaltic pumps are used in diswashers for exactly that purpose. Controlled dosage. Tpically 230 VAC 3.5W. All you need is a plug and a push button electrically speaking.Hi,
Those dishwasher pumps are for quite thin liquids, and so they may have a problem with the thick gell stuff. In addition they all have a lot of external plumbing and so the system would be fairly involved.Yes. Peristaltic pumps are used in diswashers for exactly that purpose. Controlled dosage. Tpically 230 VAC 3.5W. All you need is a plug and a push button electrically speaking.
Not at all compicated. They can handle thick concentrated washing up liquid comfortably. They are quite robust. All you need, as I said, is 230 VAC power supply and a push button to activate the motor for as long as you like. As for the detergent there are two ports. One with a tube to the detergent bottle (on the right in the picture) and one from where the detergent is dispensed.Those dishwasher pumps are for quite thin liquids, and so they may have a problem with the thick gell stuff. In addition they all have a lot of external plumbing and so the system would be fairly involved.
Please describe the specific goal of creating such a system, and what sort of use is anticipated, that matters quite a bit.
A system to be used by the general public must be far more durable than one used by a household or family. Keep in mind that perhaps 10% of the general public will totally ruin almost everything that they touch.
Just google "persitaltic pump". They come in all shapes, sizes and prices. If you go for a 230 VAC one then you don't have to bother with a DC adapter. The low voltage DC pumps tend to be a bit cheaper but then theres the adapter cost on top.ok could you indicate some model or link?
The three pumps that I have are functionally similar, but with 120 volt 60Hz motors and they are not nearly as muscular looking as the ones shown. And the connections and enclosures needed to keep the general public from electrocuting themselves would take a serious effort to make. And still we must keep in mind that 10% of the general public. The truly tragic part is that the courts and legal system seem dedicated to the prevention of natural selection.Not at all compicated. They can handle thick concentrated washing up liquid comfortably. They are quite robust. All you need, as I said, is 230 VAC power supply and a push button to activate the motor for as long as you like. As for the detergent there are two ports. One with a tube to the detergent bottle (on the right in the picture) and one from where the detergent is dispensed.
The unit shown in the video is cute and it might survive serving a family. It would not last ten minutes in a public environment.One approach:
As in #2. Definitely a buy-instead-of-make, in my opinion. I can get one delivered to my door for under $30.Amazon has this: and more like it.
Takes four AA batteries.
I'm not suggesting that the OP just twist the wires together and nail the whole thing to the wall near the sink. A certain amount of consideration will have to be given to encasing the assembly in some kind of idiot proof casing. Even in domestic setting.The three pumps that I have are functionally similar, but with 120 volt 60Hz motors and they are not nearly as muscular looking as the ones shown. And the connections and enclosures needed to keep the general public from electrocuting themselves would take a serious effort to make. And still we must keep in mind that 10% of the general public. The truly tragic part is that the courts and legal system seem dedicated to the prevention of natural selection.
Yeah, I'm sure they can be found cheaper. I just did a quick search and picked one of the first few that popped up. There are lots on the market.As in #2. Definitely a buy-instead-of-make, in my opinion. I can get one delivered to my door for under $30.
Dummy resistant takes some effort, but actually idiot proof is very difficult to achieve.I'm not suggesting that the OP just twist the wires together and nail the whole thing to the wall near the sink. A certain amount of consideration will have to be given to encasing the assembly in some kind of idiot proof casing. Even in domestic setting.
It may also work to add a cam so that each push of the button delivers one revolution worth of the stuff. That could use some really simple control, logic. Just one relay.If you want to go the peristaltic pump route, here's a pump and controller together, controlled via. a serial connection, should you want to get that complicated:
https://www.kr4.us/bartendro-dispenser-peristaltic-pump-and-controller.html
| Thread starter | Similar threads | Forum | Replies | Date |
Electric pump to dispense the hand sanitizer gel .. #2 | General Electronics Chat | 1 | |
Desoldering vacuum electric pump | General Electronics Chat | 7 | |
electric Fuel Pump | General Electronics Chat | 5 | |
| D | Electric De-Soldering Pump damages pads | Technical Repair | 27 | |
Electric Fuel Pump Prime Switch | General Electronics Chat | 66 |
