You people do know that they tried air cooled "radiators" back in the early days of automatic transmissions, don't you? Didn't work to well and killed many transmissions. In hot weather they didn't take enough heat out of the oil and degraded the oil. In cold weather they didn't let the oil get to the correct temperature and killed the clutches in the transmission. The oil to water cooler was what was settled on as the best and easiest way of keeping the transmission alive. The add on air to oil coolers like the Hayden type are put in the output line of the oil to water heat exchanger and most use a thermostat to bypass them when temps aren't over a certain point.
So you guys are saying that a ~15 to 20 PSI radiator is a problem for transmission oil at ~50 to 70PSI ? A broken oil cooler doesn't get water into the oil when running but when the engine is not running.
