EE-360 Electrical Energy Engineering
aaf8888
Joined Dec 29, 2011
11
Hi everyone,
I have this project and I really need some help to understand it and ways to start it...
Thank you in advance.
The pdf file is attached.
#12
The instructions seem perfectly clear. Design a substation that runs off 115KV.
Meanwhile, I'll tell the bosses here that this belongs in the homework section.
33,125
If you don't understand it enough to ask specific questions, then I suggest you approach your instructor and work with them on getting your understanding of the course material up to a point where you can at least start asking specific questions.
mlog
Joined Feb 11, 2012
276
I have a question, How many transformers do I need to build the cheapest substation?
Make yourself a sketch of the loads and proposed layout. It will help you come to a solution. You might have options on the number of transformers, but until you lay it out and make some initial calculations, you can't answer the question.
aaf8888
Joined Dec 29, 2011
11
Excuse me,
Can I use only one transformer to supply more than one motor.
As in this question, 4 DC motors, 3 induction motors and 2 synchronous motors.
For example, one transformer for the 4 DC motor.
And one for the 3 induction motors. Lastly, one for the synchronous motors.
Thank you
