Editor becomes very unresponsive
33,184
When I am typing a post, particularly a longer one (but not always), it is not uncommon for the editor to just get dragged down to a fraction of a snail's pace -- and by that I mean that if I type something that it takes two or three seconds for EACH character to appear! I'm assuming that this is because of communication going on with the server in response to each keystroke I make.
What's particularly annoying is that I can't just go over to another window and work on something else while I wait for the editor to catch up because as soon as I change the focus to another window whatever actions I have taken in the editor that have not yet been processed are discarded.
I don't know if there are any configuration options that might improve this. Thought?
tshuck
Joined Oct 18, 2012
3,534
It may help if you switched over to the basic editor by clicking the button on the top right of the posting menu (has a small wrench on it).
Edit: This one:
studiot
Joined Nov 9, 2007
4,998
I note that in post#3 WBahm has a roman capital I, but in the edit box I get, the I is a single vertical stroke. The capital roman I is most useful.
Yet when it is posted the default font changes.
Why is this?
33,184
something wrong with your OS? How about free memory and resources usage (could be wrongly displayed), and HDD LED?
No other app is unresponsive, including other browser windows, when this happens. Also, I have a solid state drive that is quite responsive.
takao21203
Joined Apr 28, 2012
3,702
maybe your machine is overloaded with pulling the resources maintaining the port handles and running the scripts, or some system service is faulty and is resetting all the time.
Java can be a pain when resources are scarce it might not be obvious just in the way java needs it. I think the new forums use FLASH, and thats almost a receipe for a disaster.
FLASH + java + javascript + pulling external scripts and a lot of small resources.
Before upgrading the RAM in my netbook to double, I have seen this on daily basis- delays for single keystrokes! Windows loads + starts many unneeded resources, and when there isnt enough RAM, it starts juggling between RAM sections first, then involving the HDD too.
33,184
The why do ALL other applications and browsers continue to work just fine and ONLY the editor for THIS forum is bogged down to a crawl?
tshuck
Joined Oct 18, 2012
3,534
I believe editors like the default one communicate back to the server to do all of the fancy stuff it does, which, if so, is likely where the issue lies.
Knowing what the editor is might help in finding a solution (or another editor).
33,184
I'm talking about the editor that is part of this forum -- almost certainly the same one you used to type the above.
Without using a packet sniffer, I'm only guessing, but I suspect (as stated in the first paragraph of Post #1) that it is communicating with the server for every keystroke. This has the advantage that the server can remember what was typed so that you have a saved draft of your post -- and this has come in handy several times.
