ECM issue
bbene609
Joined May 1, 2023
I have a marine ECM that supplies 0-5VDC to two injectors. Signal from the ECM to one of the injectors is intermittent and cuts the engine out and backfires.
My question is: Is there something that I can make to take the 0-5VDC from the good output of the ECM and deliver a double 0-5VDC output without increasing the load on the ECM?
Any help would be appreciated.
MOD NOTE: E-mail address removed.
WBahn
Joined Mar 31, 2012
33,108
MOD NOTE: Moved from Feedback and Suggestions.
Note that, as the description states, the Feedback and Suggestions forum is not for getting help with technical questions.
MrSoftware
Joined Oct 29, 2013
2,273
There's not enough info to really help. Try to narrow down why the power is in and out. Is there a loose wire somewhere, corroded pin in a plug, etc..? Figure out why the problem is occurring first, then you can work on a solution to the problem. Otherwise it's just stabbing in the dark and hoping for the best.
