Easy easy question (Tesla coil)
Tryui
Joined Sep 20, 2021
208
What shape of magnetic field are you looking for? How you arrange the poles produces very different results.
Shape of magnetic field
Bob
the magnetic field produces it with a solenoid quondi an electromagnet in which the field flows from the inside to the outside and if the current flowing through the wire is continuous the magnetic field is static and if the current is alternating electromagnetic induction is produced which if I'm not mistaken is an electromagnetic field
Tryui
Joined Sep 20, 2021
208
So, just wind a solenoid and put current (DC or AC) through it. What is the question?
Bob
Bob
the problem is that alternating current makes magnetic and electric fields "couple" and produces electromagnetic field that's why it insists on pulsed direct current, and I have found that it is used in welding machines and stepper motors. The operating principle is to couple a square wave to a direct current through a PWM modulation, and in detail they use a MOSFET transitor to switch on and off
BobTPH
Joined Jun 5, 2013
11,619
Turning a coil on and off with DC produces electromagnetic waves just like a sine wave would.
I still have no idea about what you are trying to accomplish.
Bob
Tryui
Joined Sep 20, 2021
208
Bob
what I want to realize is a pulsed direct current, used for example in stepper motors. So I read that you have to use a PWM pulse modulation, and then use a MOSFET transistor to switch the DC current on and off. In this case the correct being continuous has only one polarity, and if there are problems a diode is inserted to rectify it, but we always use direct current so there is no polarity exchange
BobTPH
Joined Jun 5, 2013
11,619
Stop telling us about the circuit think you need and the incorrect assumptions that led to it.
Tell us what you want the results to be and what you will do with it.
You can buy a PWM controller for almost mothing, and connect it to a coil, but what will you do when you have that?
Bob
Tryui
Joined Sep 20, 2021
208
Bob
ok by connecting it to the DC powered coil with an internal ferrite core, I get an electromagnet that mj produces a pulsed static (non-variable) magnetic field, i.e. simply turn on and off
Tryui
Joined Sep 20, 2021
208
Bob
for the electromagnetic field I think I use simple EMPs where the tutorials can be found on the internet or youtube. However, in your opinion regarding the pulsed static magnetic field, is the idea of using a PWM with a transistor okay?
Papabravo
Joined Feb 24, 2006
22,106
This is not possible. A pulsed static (non-variable) magnetic field is a contradiction. That is not how it works.
Tryui
Joined Sep 20, 2021
208
and then how do I create a pulsed magnetic field, I mean in the simplest sense that is to turn on and off for example 100 times a second, now there and after it is gone. By static we mean, created by a DC, and with a PWM turn on and off, I'm failing to understand why that's not possible. Obviously the PWM will be managed digitally as well as the number of pulses
Papabravo
Joined Feb 24, 2006
22,106
A pulsed magnetic field is created by applying and removing a DC current. If the pulses are smooth then the magnetic field will rise and fall accordingly. If the pulses are square you will get an entirely different behavior with large voltage spikes at the turnoff. Theses spikes can and will damage any switching device that you may choose to use. If you do not saturate the core, then the magnetic field strength will be proportional to the current, and the voltage across the inductor will be proportional to the derivative of the current with respect to time.
Tryui
Joined Sep 20, 2021
208
ok in this I do not scorn and I follow your advice, so since the PWM uses square waves, to create "smooth" waves as you said in the first part of the answer, how can I do?
Papabravo
Joined Feb 24, 2006
22,106
How about a sinewave with a DC offset equal to the peak voltage of the AC waveform. Something like:
\( 10\;+\;10sin(2\pi ft) \)
for some frequency
\( f \)
BobTPH
Joined Jun 5, 2013
11,619
Sorry, I cannot help you when you won’t tell me what it us you are trying to do.
This is an example of what I need you to tell me:
“I want to create a pulsed magnetic field of 200 Gauss in a cylindrical volume 2cm in diameter an 1 cm in height. The pulses will have a frequency adjustable from 1 to 3 KHz with a duty cycle of 10% to 50% and rise and fall times of less than 50us. I will use this to study the effect of a pulsed magnetic field on bacteria growth.”
With that kind of explanation, we could start exploring possible solutions.
Bob
