I recently purchased a large enclosure for my snake however the lighting/heating system keeps failing. The thermostat is connected to three separate lights in which I am using infrared heat lamps.
The lamps keep failing and I believe this may be due to the fittings being cheap plastic and not suitable for the heat lamps.I intend to switch these out with ceramic fittings however the fittings I purchased only have two connections available.
If I simply seal off the earth wire with electrical tape and install the ceramic lights will this be a risk? I guess this will mean that the system is earthed up to and including the thermostat, and that if you were silly enough to stick your finger in the socket the breaker would still operate.
Any advice appreciated.
Justin
Justin
